Re: Ever had an MSD 6AL just die on you?
[Re: A727Tflite]
#3273720
12/02/24 06:43 PM
12/02/24 06:43 PM
Posts: 10,653 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus
[Re: fourgearsavoy]
#3273797
12/03/24 06:21 AM
12/03/24 06:21 AM
Posts: 3,012 A shed in England
Tig
A shed in England
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus The MSD tech guy told me what kills them is reattaching the battery cable while running - if I recall he said it goes full field while disconnected then zaps the box when reconnected. I’m no electrical expert, still haven’t forgot my first electric shock. Yep they check it the same over here too. The battery isolation (kill) switch should turn everything off and the engine should stop. Removing the battery cables while the engine is running will still allow the engine to run IF the alternator field circuit isn't interrupted. This can cause voltage spikes as the battery acts as a type of voltage "buffer". I've had no issues with either an analogue 6AL or a Grid when the kill switch is checked but on the grid we do have a MSD filter (capacitor), which we also take the voltage supply for the Racepak from. This filters out any RFI or relay spikes though we've fitted flywheel diodes to the relays where possible.
[Re: A727Tflite]
#3273829
12/03/24 11:25 AM
12/03/24 11:25 AM
Posts: 13,581 Marion, South Carolina [><]
an8sec70cuda
So if your kill switch works properly, this won't be an issue.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3273845
12/03/24 12:20 PM
12/03/24 12:20 PM
Tig
A shed in England
So if your kill switch works properly, this won't be an issue. Never had an issue, first started racing in '96 and they check it at least once every season. I'm always switching it on and off too but usually the car isn't running.
