Re: Smoothed firewall - wiring bulkhead location
[Re: Stanton]
#3265186
10/19/24 04:17 PM
10/19/24 04:17 PM
Posts: 20,419 north of coder
moparx
couple of questions.......... 1 - where was it before ? 2 - have you considered moving it down low, coming through the top of the toe board ? [passenger's side perhaps ?] doing that would keep your smooth firewall looking great ! at least that would be what i would do, after spending the time you did smoothing everything out.
[Re: topside]
#3265333
10/20/24 01:43 PM
10/20/24 01:43 PM
Posts: 9,081 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Yes, trying to keep things clean and tidy. I really don't want anything on either the firewall or the inner fenders if I can help it. The ECU and MSD will likely go inside, The battery will be in the trunk and I intend to build a dustproof box to house the misc front end relays and electrical connections and I'll probably use the stock battery location for that. As it is I consider the Terminator harness to be very "messy" but it is what it is. Don't really want to tear into that - at least not yet! I'm thinking you should make sure everything works & is bug-free before drilling/cutting/finalizing. Everything is tested before install. The engine was fired with the whole EFI system installed prior to putting it in.
[Re: Stanton]
#3265340
10/20/24 02:15 PM
10/20/24 02:15 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Couple shots of the firewall area . After feeling around behind the heater there seems to be a good amount of space between the back of the heater and the firewall to the left of the blower motor - just above the tunnel. Probably worth pulling the heater back out to have a look and if so to cut the holes.
[Re: Stanton]
#3265343
10/20/24 02:36 PM
10/20/24 02:36 PM
Posts: 3,004 A shed in England
Tig
A shed in England
When I re-wired my Challenger using a couple of Painless wiring kits, I mounted the fuse box under the dash and left of the glove box. I ran the cables to the front under the fenders to keep the wires out of the engine bay. Since I installed all the Racepak stuff it seems pretty cluttered again though
[Re: Tig]
#3265456
10/20/24 11:12 PM
10/20/24 11:12 PM
Posts: 4,649 Motor City
6PKRTSE
Motor City
I filled my heater blower motor opening, any unused factory holes and bulkhead connector hole on my firewall and inner fenders. I also have my wiring running along the top of the inner fenders. My Racepak sensors are all piggy backed along my snout bars.
[Re: 6PKRTSE]
#3265476
10/21/24 08:28 AM
10/21/24 08:28 AM
Posts: 10,020 MI, usa
dvw
MI, usa
Though it was difficult, mine goes thru the passenger floor into the RF frame rail. Comes out just behind the motor plate. Also just did a small block turbo Duster. The lights, fan, and boost controller go thru the left fender well. The harness is attached to the fender bolts that are slightly longer. The main engine harness comes thru a grommet behind the wiper motor. Doug
[Re: Stanton]
#3265513
10/21/24 11:25 AM
10/21/24 11:25 AM
Posts: 16,655 On the run…
BloFish
On the run…
Tidy
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Stanton]
#3265793
10/22/24 10:54 AM
10/22/24 10:54 AM
moparx
how about using conduit connectors ? i believe they use something like a compression fitting, and at one end, they have threads that use those 8 [?] pronged nuts to fasten to electrical boxes. that setup could be "bolted" [zip tied, etc.] to the upper part of the inner fender in the wheel house area. just tossing out a simple idea........
[Re: Stanton]
#3265998
10/23/24 11:05 AM
10/23/24 11:05 AM
moparx
i have used that nylon wrap material, and it's pretty tough stuff, good for many installations, as it comes in many sizes from 1/4" to [i believe] 2". it's also very reasonably priced, cheap in fact, and it usually comes in 18ft lengths. however, it takes a little practice to wrap around your wire bundle, especially if you are like me, being "all thumbs". i terminate the ends with a piece of marine heat shrink tubing for good looks. not really necessary, but that's just me. and it's WAY better looking than that cheap plastic, ringed, split loom that everyone seems to use too much of, everywhere under the hood.
