Re: Time to rewire my racecar? Show me what you have?
[Re: Cab_Burge]
#3265193
10/19/24 03:58 PM
10/19/24 03:58 PM
Posts: 20,650 north of coder
moparx
for whatever it's worth, i have started to use marine grade heat shrink with the glue inside for all my wiring chores over the last couple of years. i think it's just a little more protection from whatever moisture may find it's way in and around any terminal connections. is it really necessary ? who knows ? but it makes me feel a little better......... i guess.............
[Re: Cab_Burge]
#3265272
10/20/24 02:35 AM
10/20/24 02:35 AM
Posts: 10,163 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Twenty eight years and some add ons will create issues, also i recently had to track down a dead short in the starter circuit, and the whole harness got opened up to figure it out. Turned out to be a braided steel presure line got too close to the engine compartment starter switch.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: cl440]
#3265298
10/20/24 09:53 AM
10/20/24 09:53 AM
Posts: 2,562 PA
moparacer
PA
I dont have any pics but the ARC 8000 kit was very easy to install and is a very neat and clean set up. I have had the same unit in 2 different cars and it has been rock solid reliable. I wouldn't hesitate to buy another if needed. I love my ARC 8000. Been in the car for 15 years.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 5.44-126 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3265789
10/22/24 09:49 AM
10/22/24 09:49 AM
gregsdart
Ordered the top of the line K&R delay box last night . At a total of $1220 so far this is costing more than i figured in,,,,,, Question, what are you guys mounting tour fuse panels on?
[Re: gregsdart]
#3273783
12/02/24 11:53 PM
12/02/24 11:53 PM
gregsdart
Pictures of the new switch/delaybox panel and fuse panel locations. Used Lexan for rhe fuse panel, some circuits will be fused on a seperate block ,like the drivers fan, so it is independant of the K&R fuse block. Haven't started to route the wires yet, but have all tagged with destination. Next, bundle them up, do my best to make it look neat.
