Re: Oil Filter
[Re: cudaman1969]
#3232335
05/12/24 03:01 PM
05/12/24 03:01 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I’m not running a filter, too much restriction -hp loss... Seems like you could find a safer way to squeeze out a bit more performance w/o sacrificing engine durability. And that's ASSuming you can verify that removing the filter does, in fact, show improved on-track performance. Ok, why do we remove the air filter or run the drag car without one? Anything that restricts flow.. I don't consider that an apples to apples comparison for "restriction" examples, but maybe it's just me
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Oil Filter
[Re: Brad_Haak]
#3232647
05/13/24 09:26 PM
05/13/24 09:26 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I’m not running a filter, too much restriction -hp loss... Seems like you could find a safer way to squeeze out a bit more performance w/o sacrificing engine durability. And that's ASSuming you can verify that removing the filter does, in fact, show improved on-track performance. Ok, why do we remove the air filter or run the drag car without one? Anything that restricts flow.. I don't consider that an apples to apples comparison for "restriction" examples, but maybe it's just me Not just you. The oil pump is a positive displacement pump. The engine is not. The oil pump will pump a fixed volume with each rotation, with or without a filter. You need to shorten the rotor length to reduce the oil pumped and reduce the hp to drive the pump. Reducing spring pressure will tallow the ho consumed by the pump too.
