Re: disable a modern car but quick fix? [Re: 360view] #3177699
09/24/23 09:06 AM
09/24/23 09:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Pull the fuel pump relay, easy to reverse, car won't start but it will crank so they won't think any funny business is up with the keys.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: disable a modern car but quick fix? [Re: Bad340fish] #3178107
09/25/23 01:15 PM
09/25/23 01:15 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
It will set a code for the fuel pump circuit and he will have to clear it to pass the inspection but when they take it for inspection it will tell them the codes have recently been cleared and will still not pass the inspection, thats why I recomended the starter wire, it won't set a code.
Re: disable a modern car but quick fix? [Re: HotRodDave] #3178223
09/25/23 07:51 PM
09/25/23 07:51 PM
Andrewh Offline OP
Andrewh  Offline OP
is there a starter relay like in mopars? or just small wire to the starter?
Re: disable a modern car but quick fix? [Re: Andrewh] #3178345
09/26/23 11:35 AM
09/26/23 11:35 AM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
little tiny wire just slides over the blade. There is a big fat wire but it is activated by the little one so you only need to slide that one off.
Re: disable a modern car but quick fix? [Re: Dcuda69] #3178451
09/26/23 05:39 PM
09/26/23 05:39 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Originally Posted by Dcuda69
No inertia switch on a 16 Camry. AFAIK Ford is the only passenger car that used them and that was 30 yrs ago.
Crown Vics had them until end of production in 2011 I believe. Nothing much newer has them though- the disablement of the fuel pump after a crash comes from other sources, usually the ABS unit or restraints control module.
Re: disable a modern car but quick fix? [Re: Blusmbl] #3179797
10/01/23 07:00 AM
10/01/23 07:00 AM
o
ChryCoGuy Offline
ChryCoGuy  Offline
o
If it's keyless remote entry with a start button as opposed to a standard ignition key, couldn't you just pull the battery out of the key fob? If the car's locked she won't be able to get in unless she pulls the hidden key out of the fob to unlock using the key cylinder on the door. Even if she gets inside, the car won't start. I'm not sure about Toyota, but on Hondas the only way to start the car with keyless and a dead fob is to hold the fob up near the start button while you are pushing the button, so that it can read the fob and determine that the key is present. I suspect they all work basically the same and I don't imagine she would know how to start the car with a dead fob. Might be worth a try.
Feeling for you on the dementia issue. Went through that for many years with the MIL. The car issue worked alright for her as she decided that she shouldn't drive anymore all on her own. She still wanted to be able to see her car every day as she had bought it all on her own and was still very proud of it. So we kept it there for her and she never once attempted to drive it. Best of luck to you. It's a tough situation to be into.
Re: disable a modern car but quick fix? [Re: ChryCoGuy] #3180032
10/01/23 07:57 PM
10/01/23 07:57 PM
PA
70Duster Offline
70Duster  Offline
PA
I just read the whole thread and on the last post ChryCoGuy said exactly what I was going to post. Just take the battery out of both remotes and the problem is easily solved.
