Re: Stroker combo 440 block
[Re: sean1970]
#3174730
09/12/23 03:45 PM
09/12/23 03:45 PM
Posts: 226 Anchorage, Alaska
metallicareload
Anchorage, Alaska
You’ll have 0.005” pistons above deck by my math, assuming 10.725” deck height. Not sure if you'd have trouble between the pistons and counterweights
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: sean1970]
#3174760
09/12/23 05:32 PM
09/12/23 05:32 PM
Posts: 30,520 Oregon
AndyF
Most 4.25 cranks have a minimum rod length listed in the catalog. Double check to see what the mfg says. I'd use a 7.10 rod in an RB block but I have used 6.535 chevy rods in low deck engines. Also, if you haven't verified the deck height of the block then don't assume that it meets factory specs or that it will clean up at factory specs. Most Mopar blocks need to be cut a bunch to square them up.
[Re: AndyF]
#3174767
09/12/23 06:03 PM
09/12/23 06:03 PM
Posts: 1,773 NW Indiana
fbs63
NW Indiana
Most 4.25 cranks have a minimum rod length listed in the catalog. Double check to see what the mfg says. I'd use a 7.10 rod in an RB block but I have used 6.535 chevy rods in low deck engines. Also, if you haven't verified the deck height of the block then don't assume that it meets factory specs or that it will clean up at factory specs. Most Mopar blocks need to be cut a bunch to square them up. The crank counterweights will have to be cam cut a LOT to clear at BDC. Add mallory metal to balance it and its not worth it.
[Re: fbs63]
#3174777
09/12/23 06:49 PM
09/12/23 06:49 PM
AndyF
Here is a rotating assembly that I used in my Duster engine. This was a low deck with a 4.250 stroke Callies crankshaft, 6.535 Crower rods and then a set of semi-custom pistons from Diamond. We had to turn the counterweights down on a lathe but I don't think the crank required any metal to balance. I think we just had to dimple it and it was good to go. The rotating assembly was fairly lightweight. Around 2300 gram bobweight I think. This was a fairly expensive engine to build. These days with an RB block I'd use a stroker kit with 6.800 or 7.100 rods and call it a day.
[Re: sean1970]
#3174811
09/12/23 08:44 PM
09/12/23 08:44 PM
Posts: 4,300 Prospect, PA
BSB67
Prospect, PA
Would this be a workable combo 4.375 bore 2.06 comp height 4.25 stroke and a 6.535 bbc rod. Do you already have the pistons?
[Re: sean1970]
#3174876
09/13/23 08:45 AM
09/13/23 08:45 AM
Posts: 9,767 Weddington, N.C.
Streetwize
Weddington, N.C.
that's an interesting idea, I have 6.535 and a 4.30" stroke in my low deck 517, I Suppose if the piston skirts were dimensionally the same as a low deck 451 or 511 (1.32" CH slug) the compression height above the pin might not matter as far as rotational clearance, Heres a pic of my JE pistons and short block. I think my Compression height was like 1.30"
But if you are talking about like an OEM type six pack or TRW 11.5 domed slug.....I would say no way the skirts are way too long.
If you have the crank and rods already build a low deck or swap out the rods. if you have the pistons maybe sell them to someone with a low compression 440?
But if you're building it from scratch and you have to get pistons made anyway....It would probably work if the skirts are as I stated before.
[Re: sean1970]
#3174997
09/13/23 04:27 PM
09/13/23 04:27 PM
Posts: 9,867 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Yes I know I was just curious if it was possible or not it would probably interfere with the crank. I had found a set of piston new with the 2.06 comp height. I would pass. Do it with the right parts and you will sleep better. I am always in favor of the most cubes you can work into a combo at a reasonable cost, especially for a dual purpose combo. A bigger motor makes more torque down low, and takes less time to get through the first half of each gear, having more average HP down there. Add in the benefits of less required rpm on valvetrain, more stall from the same converter, the list favoring a big stroker is long. Just keep within the reasonable strength limits of the block you run.
[Re: gregsdart]
#3175017
09/13/23 05:39 PM
09/13/23 05:39 PM
Streetwize
Weddington, N.C.
Long rods would be better in terms of longevity....at least in theory
That said the Pits are full of 9.8 deck 496" BB Chevies with 4.25" cranks and 6.135 or at best 6.385" (+.250) rods.
I have 6.2" rods in my 4.25" stroke 440" Mopar smallblock and 6.123" (340 mopar rods) in my 9.5" deck 427" Windsor ford.
[Re: HardcoreB]
#3175031
09/13/23 07:31 PM
09/13/23 07:31 PM
AndyF
The longer the rod the less side-loading it does to the cylinder wall...I wouldn't do an RB with anything less than 7.1 rods IMO. Yes, less side wall loading but what I really like about the longer rod is that it keeps the pistons out of the crankcase. The further you can keep the pistons away from the big rotating cloud of windage the better. Some engines such as SBF and BB Chevy engines make do with short rods. The short rod motors run hard, but given the opportunity I prefer to use a long rod.
[Re: AndyF]
#3175121
09/14/23 08:54 AM
09/14/23 08:54 AM
Posts: 1,047 The Great White North
RAMM
Something to consider about the tall 2.06" pistons is these will have inherently more stability than a much shorter C.H. piston which could maybe offset some of the side load issues being discussed. IE. It should take longer to become a skirt/ring wear issue if at all. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
