battery cable hy- flex #3149768
06/08/23 03:48 PM
06/08/23 03:48 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hi everyone, I recall seeing an episode on one of the car shows that had the Red Battery cable mounted in the trunk but the wire they used was a super hy-flex, it basically laid flat and just fell into the contours of the floor pan. does anyone know who makes and where to buy.
the wire i have now is on the older side and i am going to replace it just looking for something better and more flexible.
thank you
Thank you
Kiddart
Re: battery cable hy- flex [Re: Kiddart] #3149777
06/08/23 04:20 PM
06/08/23 04:20 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Google hi flex battery cable
Welding cable is also pretty flexible.
Re: battery cable hy- flex [Re: GomangoCuda] #3149849
06/08/23 09:35 PM
06/08/23 09:35 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Another vote for welding cable. Super resilient, super flexible- and remains that way regardless of enviroment. Its also readily available at most bulk electrical contractor suppliers
Re: battery cable hy- flex [Re: moparjim79] #3149852
06/08/23 09:46 PM
06/08/23 09:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have a lot of new welding cable depending on what size you need. Also have the lugs for some sizes. PM me your needs if you'd like wink
