Best Price on Titanium 2.45 Intake Valves?
#3119074
02/05/23 01:41 PM
02/05/23 01:41 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
Who do you guys like for Titanium intake valves? I gota say, the prices I have found so far from Ferrea are not agreeable with my pocket book...
Re: Best Price on Titanium 2.45 Intake Valves?
[Re: FastmOp]
#3119146
02/05/23 05:44 PM
02/05/23 05:44 PM
Dragula
So I went on the Manley website. A standard SS valve for a G2 Hemi is 138grams......A damn Titanium one for a a BAE is 137grams....granted the stems are a tad different in size is .003 different, they are listed as the same weight...
Ferrea does not give the weights...How do even compare?
[Re: LA360]
#3119212
02/05/23 10:26 PM
02/05/23 10:26 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
We run them all depending on application. Ferrea, Manley, Trick Titanium (Scitek), Xceldyne, Del West. About in that order price wise.
[Re: sr4440]
#3119220
02/05/23 11:07 PM
02/05/23 11:07 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Have to ask, you referenced a 6200 shift point in your other thread.
Is your plan to keep it there? If so, IMO, would not be worth the cost to go to a Ti valve.
You could save a bunch of weight with a smaller diameter spring and ti retainers/locks. (that's what I did)
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700
[Re: INTMD8]
#3119237
02/06/23 08:22 AM
02/06/23 08:22 AM
Dragula
You could save a bunch of weight with a smaller diameter spring and ti retainers/locks. (that's what I did) Retainers & locks are already Titanium. And, this is the second time I have killed the intake valve springs. I do not know the weight difference between a SS Hemi 2.25 stock valve and a SS 2.40, but it must be enough, along with lack of oil on the valve springs to wipe everything out each year....So in the interest of possibly saving the intake valve springs, I am looking into 2.40 to 2.45 Titanium valve springs regardless of shift point. I also bought a newer cam that has a milder ramp rate and only requires 180lbs closed..Its -.030 lift as well, but at this point, if I can't drive it or race it, any move in the positive direction is good.....I will be checking my current ones, but I think they are north of 220lbs closed. So I will also need new springs as well, and watching Steve Tech, he did not give any brand names out that use the newer designs, so that might be a crap shoot. If I have triple springs, I will look for a set of doubles. I think I should have paid more attention to the setup and parts selected than I did. For racing, eveything would probably be just fine, but add in all the street miles, and things change drastically.
[Re: Dragula]
#3119384
02/06/23 06:38 PM
02/06/23 06:38 PM
Posts: 154 Canada
cuda499
Canada
Who do you guys like for Titanium intake valves? I gota say, the prices I have found so far from Ferrea are not agreeable with my pocket book... I put victory's in my hemi, but they where 2.40. fwiw i wouldnt do a valve that big in S.S. Put proper seats in it, and they work just fine.
[Re: Dragula]
#3119773
02/07/23 09:50 PM
02/07/23 09:50 PM
Posts: 3,395 Pa
Hot 340
Pa
Ferrea does not give the weights...How do even compare? My Manley 2.250s weigh in at 146 grams
[Re: Hot 340]
#3119775
02/07/23 09:54 PM
02/07/23 09:54 PM
Dragula
Ferrea does not give the weights...How do even compare? My Manley 2.250s weigh in at 146 grams Are those SS or Ti?
[Re: Dragula]
#3119778
02/07/23 09:59 PM
02/07/23 09:59 PM
Posts: 3,395 Pa
Hot 340
Pa
Ferrea does not give the weights...How do even compare? My Manley 2.250s weigh in at 146 grams Are those SS or Ti? SS
[Re: Hot 340]
#3119944
02/08/23 01:35 PM
02/08/23 01:35 PM
Dragula
Called Brian at Victory and had a really good conversation about this.....My thoughts are the older 2.25 valves were never too heavy to cause an issue, and the new 2.40 stainless valves are that much heavier that this has become an issue....When I look at ALL the BB drag and drive engines out there, at least when they post the specs, they all have Titanium intake valves at this size. The new GM 632 crate motor has them for both intake, and exhaust...So it seems like its one of those hidden necessities....I don't know, but that is where my thinking is headed.
He quoted me: $134/valve $40/coating the whole valve (no lash caps needed) $22/Retainer $7/Lock X8_____________ $1624 for 8 new intake valves, locks & retainers
[Re: Dragula]
#3119968
02/08/23 02:12 PM
02/08/23 02:12 PM
Posts: 154 Canada
cuda499
Canada
He quoted me: $134/valve $40/coating the whole valve (no lash caps needed) $22/Retainer $7/Lock X8_____________ $1624 for 8 new intake valves, locks & retainers Always cheaper to do it the right way once.
[Re: Dragula]
#3120245
02/09/23 02:18 PM
02/09/23 02:18 PM
Posts: 911 London, England
mopar_mark
London, England
He quoted me: $134/valve $40/coating the whole valve (no lash caps needed) $22/Retainer $7/Lock X8_____________ $1624 for 8 new intake valves, locks & retainers I personally like lash caps, especially the style which are held in place by the retainer/locks. Did he not recommend a valve seat for Titanium Valves, maybe because mine is a turbo application it has Berrilium Seats. I know it helps with heat dissipation
