Re: Stripped Upper Ball Joint [Re: TJP] #3083325
10/04/22 06:13 PM
10/04/22 06:13 PM
moparx  Offline
772C[hinesium] shruggy whistling panic boogie up biggrin
all jokes aside, the "C"s, being slightly oversized, work wonders in some instances.
there are circle track joints made by Howe that also work good as well, although i can't supply the part numbers.
chrysler upper and lower screw-in joints are very popular with the circle track guys, and Speedway Motors handle all their products.
Re: Stripped Upper Ball Joint [Re: moparx] #3083873
10/06/22 04:34 PM
10/06/22 04:34 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
The control arms will always appear stripped.
I recently had one upper ball joint that felt as if it would strip/would not take torque.
I'm a mechanic and I've had issues with press in ball joints at work that were mis-sized.
You measure several different parts and they are a few thousands different.
At the time I just happened to have some new spare front end parts and another new ball joint measured larger than the part with the causing the problem.
The spare ball joint went in and I was able to torque it no problem.
Re: Stripped Upper Ball Joint [Re: TJP] #3085552
10/12/22 06:32 PM
10/12/22 06:32 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i had mine TIG welded, worked out fine
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
