Converter sprag question .
#2978291
10/25/21 04:57 PM
10/25/21 04:57 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
Hi all , just another thinking out loud question regards converters . When using a mechanical diode/sprag has anyone noticed any difference to regular sprags ? I know the mechanical is considered stronger, almost unbreakable . Street/strip usage , transbrake .
Tex
Re: Converter sprag question .
[Re: tex013]
#2978482
10/26/21 08:19 AM
10/26/21 08:19 AM
an8sec70cuda
My cuda used to kill a "super" sprag every 100 runs or so. Went to a mechanical diode and no more problems. Last converter I had done we went spragless. Used to be that the spragless converters would slip a lot up top, but that doesn't seem to be the case anymore.
[Re: an8sec70cuda]
#2978602
10/26/21 02:00 PM
10/26/21 02:00 PM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
My cuda used to kill a "super" sprag every 100 runs or so. Went to a mechanical diode and no more problems. Last converter I had done we went spragless. Used to be that the spragless converters would slip a lot up top, but that doesn't seem to be the case anymore. We were chasing an issue with the car a few years ago. Inconsistent ET's and reaction times. Lost MPH etc..... We changed ignitions, fuel pumps etc..... Finally we started to look at the symptoms of a failing sprag in the converter. Called Transmission specialties and discussed it with them. They convinced me to buy one of there super 8 9" spragless converters........One of the best purchases I have ever made! ET, MPH, Consistency all came back!
[Re: cl440]
#2978661
10/26/21 04:58 PM
10/26/21 04:58 PM
tex013
Sydney,Australia
thanks guys , i had been having 60 move around which is why i pulled trans . Only just got it back in last week . When i sent converter back to USA for service it came back with a mech diode and pretty much everything replaced but no explanation . There was some metal in pan , trans builder said it came from converter as rest of trans was good apart from wear on stator support (?) splines . If it picks up to the 60 i expect i should see better ET maybe a pinch of MPH if sprag was slipping
Tex
[Re: tex013]
#2978714
10/26/21 08:18 PM
10/26/21 08:18 PM
Posts: 1,030 ohio
67mprfan
ohio
thanks guys , iThere was some metal in pan , trans builder said it came from converter as rest of trans was good apart from wear on stator support (?) splines .
Tex I just went through this metal went through the whole transmission but inside was good, snap ring broke in the converter and destroy it . I have a new converter(actually2 now) and the 1 in the car has a mechanical diode seat of the pants feels great
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2978765
10/26/21 11:45 PM
10/26/21 11:45 PM
tex013
Sydney,Australia
[ [/quote] I just went through this metal went through the whole transmission but inside was good, snap ring broke in the converter and destroy it . I have a new converter(actually2 now) and the 1 in the car has a mechanical diode seat of the pants feels great [/quote]
Converter was 5700 then with engine top end change 6000 . Explained this also and had it tightened back towards the 5700 . Definately feels better on street , firmer/tighter like my 5000 vert in spare trans . Now all i need is the sanction legal BS to be done locally so we can get back on track .
Tex
[Re: 67mprfan]
#2978778
10/27/21 02:44 AM
10/27/21 02:44 AM
Posts: 43,127 Bend,OR USA
Any time slips to look at yet? If so what are the 60 ft. times now compare to before?
[Re: Cab_Burge]
#2978974
10/27/21 04:35 PM
10/27/21 04:35 PM
tex013
Sydney,Australia
Any time slips to look at yet? If so what are the 60 ft. times now compare to before? Cab , there is legal argy bargy going on over track sanction now , after 3 1/2 months closed . I kind of doubt any passes here in Sydney till end of year at earliest . I am racing interstate in December so its a long wait to know and 13/14 hour drive to get there. Tex
[Re: 440Jim]
#2980115
10/31/21 05:07 AM
10/31/21 05:07 AM
tex013
Sydney,Australia
Well looks like t&t this friday weather permitting . Sanction body ok'd by state govt , own track , legal argy bargy in court same day . Crossing my fingers though sure to be a bunfight due to lack of racing , i hope there is a number limit , and as usual the hero time trialists . I want to try leaving a little lower rpm .
Tex
