Re: WiFi Extenders.
[Re: BlueRacer69]
#2894982
03/02/21 08:51 PM
03/02/21 08:51 PM
Posts: 9,432 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Of course they work and work well. Take any good old wifi router you have and if its on there firmware list, flash it, set it up your way and dont look back. https://dd-wrt.com/ OR you can buy the cheap mainstream units that are plug and play that any 5th grader can hack. Id have a vpn in the picture, anyone can DL cali linux and watch a u tube vid and be on your network and even the dummies can do it for a hundred bucks or so.
STOP POTATO HATE!
Re: WiFi Extenders.
[Re: BlueRacer69]
#2895050
03/02/21 11:25 PM
03/02/21 11:25 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I just a modern more powerful router that fixed my problems. I was considering a booster but no need now.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: WiFi Extenders.
[Re: BlueRacer69]
#2895064
03/03/21 12:03 AM
03/03/21 12:03 AM
Posts: 30,997 Oregon
AndyF
Has anyone here bought one? Do they really work or are they just a piece of worthless crap. Thanks for any info. What are you trying to do? If you want to extend wifi inside your house you can use the TP-Link stuff that sends the signal across the house wiring. It works okay, I've used that solution for years since we have a single story ranch type house that is spread out. I tried a cheap wifi extender and it didn't work.
Re: WiFi Extenders.
[Re: AndyF]
#2895378
03/03/21 08:17 PM
03/03/21 08:17 PM
Posts: 727 Michigan
BlueRacer69
Has anyone here bought one? Do they really work or are they just a piece of worthless crap. Thanks for any info. What are you trying to do? If you want to extend wifi inside your house you can use the TP-Link stuff that sends the signal across the house wiring. It works okay, I've used that solution for years since we have a single story ranch type house that is spread out. I tried a cheap wifi extender and it didn't work. I'm trying to extend my WiFi signal so it reaches outside to my barn. That is where I work on my cars at. Right now I have a WiFi Router in my house for internet service from AT&T, but the signal won't reach out back to my barn about 50 feet behind the house. I was thinking maybe one of these small WiFi extenders that plug into a wall socket might help boost the signal to reach my barn. Whats everybodys thinking. Do they work? Thanks.
Re: WiFi Extenders.
[Re: AndyF]
#2895658
03/04/21 02:19 PM
03/04/21 02:19 PM
Posts: 727 Michigan
BlueRacer69
Any way you can run a cable out there? Do you have power to the barn? If so you might be able to have cable go out there from your router. Good suggestion but not really feasible.
Re: WiFi Extenders.
[Re: BlueRacer69]
#2895979
03/05/21 10:48 AM
03/05/21 10:48 AM
Posts: 4,766 Holland MI Ottawa
2boltmain
Holland MI Ottawa
My detached garage has a streaming TV and that TV is approximately 65 feet from my router. Not enough signal. I bought an extender with two antennas from Best buy for $50. I was skeptical. I plugged it in at the outlet nearest the garage yet furthest from my house router- so my extender is approximately 38 ish feet from the garage TV. My signal is now plenty strong enough for the streaming TV and me playing on my laptop.
Keep old mopars alive.
Re: WiFi Extenders.
[Re: BlueRacer69]
#2896030
03/05/21 12:39 PM
03/05/21 12:39 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
In the past I have had success with simple & cheap DIY parabolic reflectors http://blog-on-wifi.blogspot.com/2011/11/deep-dish-cylindrical-parabolic.htmland “Pringles Can Antennas” (Google it) to extend WiFi range in a “rifle shot” direction. I have also used 30 gallon galvanized steel garbage cans to boost 800 Mhz band cell phone signals very similar to pringles can method. The cell antenna needs to be about 4.5 inches from the bottom of the 30 gallon garbage pail. The “coaxial multi-dipole” WiFi antennas like the D-Link model number ANT24-0700 boost signal in a 360 degree circle by redirecting the signal “wasted” in the up and down directions.
Re: WiFi Extenders.
[Re: 2boltmain]
#2896033
03/05/21 12:43 PM
03/05/21 12:43 PM
Posts: 727 Michigan
BlueRacer69
My detached garage has a streaming TV and that TV is approximately 65 feet from my router. Not enough signal. I bought an extender with two antennas from Best buy for $50. I was skeptical. I plugged it in at the outlet nearest the garage yet furthest from my house router- so my extender is approximately 38 ish feet from the garage TV. My signal is now plenty strong enough for the streaming TV and me playing on my laptop. Hey 2boltmain. What brand name WiFi Extender did you buy? I hear some are good and others are junk. Thanks.
Re: WiFi Extenders.
[Re: BlueRacer69]
#2896675
03/07/21 08:28 AM
03/07/21 08:28 AM
2boltmain
Holland MI Ottawa
My detached garage has a streaming TV and that TV is approximately 65 feet from my router. Not enough signal. I bought an extender with two antennas from Best buy for $50. I was skeptical. I plugged it in at the outlet nearest the garage yet furthest from my house router- so my extender is approximately 38 ish feet from the garage TV. My signal is now plenty strong enough for the streaming TV and me playing on my laptop. Hey 2boltmain. What brand name WiFi Extender did you buy? I hear some are good and others are junk. Thanks. Heres the unit I purchased.: Linksys AC750 https://www.bestbuy.com/site/linksys-ac750-boost-range-extender-white/4580700.p?skuId=4580700
Re: WiFi Extenders.
[Re: 2boltmain]
#2896759
03/07/21 01:33 PM
03/07/21 01:33 PM
Posts: 16,474 On the run…
BloFish
On the run…
I have the same one, works great.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: WiFi Extenders.
[Re: 2boltmain]
#2896765
03/07/21 02:05 PM
03/07/21 02:05 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
My detached garage has a streaming TV and that TV is approximately 65 feet from my router. Not enough signal. I bought an extender with two antennas from Best buy for $50. I was skeptical. I plugged it in at the outlet nearest the garage yet furthest from my house router- so my extender is approximately 38 ish feet from the garage TV. My signal is now plenty strong enough for the streaming TV and me playing on my laptop. Hey 2boltmain. What brand name WiFi Extender did you buy? I hear some are good and others are junk. Thanks. Heres the unit I purchased.: Linksys AC750 https://www.bestbuy.com/site/linksys-ac750-boost-range-extender-white/4580700.p?skuId=4580700 I'm going to try this one! Thank you!
GY3 71 Demon 340
Re: WiFi Extenders.
[Re: ricomondo]
#2896919
03/07/21 11:20 PM
03/07/21 11:20 PM
Posts: 727 Michigan
BlueRacer69
My detached garage has a streaming TV and that TV is approximately 65 feet from my router. Not enough signal. I bought an extender with two antennas from Best buy for $50. I was skeptical. I plugged it in at the outlet nearest the garage yet furthest from my house router- so my extender is approximately 38 ish feet from the garage TV. My signal is now plenty strong enough for the streaming TV and me playing on my laptop. Hey 2boltmain. What brand name WiFi Extender did you buy? I hear some are good and others are junk. Thanks. Heres the unit I purchased.: Linksys AC750 https://www.bestbuy.com/site/linksys-ac750-boost-range-extender-white/4580700.p?skuId=4580700 Thanks everyone, I'll try that Linksys AC750 and see what happens. Many Thanks. I'm going to try this one! Thank you!
