2007 Ram 1500 Transmission shift control module
#2646670
04/19/19 12:04 AM
04/19/19 12:04 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I figure that plenty of members here own Ram trucks of this vintage so I thought I'd pass along a bit of info. The 545RFE trans that backs the 5.7 HEMI is a decent trans but at 325,000 miles, I am about to dig into the transmission again to change the shift control solenoid. The symptoms leading to this: Loss of 1st gear and overdrive as well as torque converter lockup. 2nd, 3rd and 4th work fine, as does reverse. Fluid level was 1/2 qt low. Not enough to cause any trouble. In July 2016 at 265,000 miles, I experienced the same symptoms. The MIL came up on the dash, the code came up a P 0750: Shift control solenoid. I did a search that offered a few YouTube videos on replacing the solenoid pack. The fluid gets drained, pan removed, then out comes both filters. The valve body comes down then the electrical connector is released for the solenoid pack. It comes apart easily and goes back together just as easily. In 2016, it was $240 with a $200 core from the nearby NAPA store. I never heard of a core on an electrical part like this but I went with it. Now almost 3 years later but only approx 60,000 miles, it has failed again. NAPA no longer offers the remanufactured unit. They have a new Echlin part for $319. The closest one is in Montana. I'm in CA. By next Friday I may have it for the weekend. I checked with the local Dealer: $450 and it is backordered with no estimate of availability. With millions of these trucks on the road, how can that be?
Re: 2007 Ram 1500 Transmission shift control module
[Re: Kern Dog]
#2647458
04/21/19 03:31 AM
04/21/19 03:31 AM
Guitar Jones
That was rude. Also, W-T-F makes you think that an anonymous dude on ebay would be any better than an OEM part from the dealer? NAPA is surely better than Vato Zone, O'Riellys or the other chain stores, right? The dealer doesn't have them? I don't know, just a guess. And NAPA? Maybe, maybe not. They sure charge more though.
[Re: Guitar Jones]
#2647462
04/21/19 05:50 AM
04/21/19 05:50 AM
Kern Dog
Granite Bay CA
The dealer I called claimed that they were on nationwide backorder with no estimate of availability. Price was $450! This is my daily driver ! I do have a backup driver but I prefer a truck for my work. Ideally, the OEM part is what I'd get but as a second choice, the NAPA stuff has been good quality. Their price with a small discount was $292. On a side note, I do prefer OEM brake pads though. I find they last longer than the aftermarket stuff I've used.
[Re: Kern Dog]
#2647824
04/22/19 01:00 PM
04/22/19 01:00 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
That was rude. Also, W-T-F makes you think that an anonymous dude on ebay would be any better than an OEM part from the dealer? NAPA is surely better than Vato Zone, O'Riellys or the other chain stores, right? Doing a little research before you click "BUY" takes almost no effort. See who is selling it and where it is from ? Some dealers probably sell more through ebay then their own walk up parts counter. 30 seconds of searching shows that chrysler no longer sells them as 'new' but only remaned, which sucks and the high price you are being quoted probably includes the $100 core charge. I like this place for most OEM parts purchases not done via ebay. https://www.moparamerica.com/oem-parts/mopar-solenoid-valve-body-68002342afOnce upon a time Napa may have been better, those days are gone. Made in china is made in china, I will not pay the premium for the same imported junk.
