Rear end brake hardline #2646293
04/18/19 12:25 AM
04/18/19 12:25 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Changing fron a 9 1/4 to 8 3/4 in my 74. Need the brake hardline for the 8 3/4. Will aCbody line work or do I use the existing line and make it work?
Abe Lincoln
Re: Rear end brake hardline [Re: dart4forte] #2646398
04/18/19 09:56 AM
04/18/19 09:56 AM
scratchnfotraction Offline
truck 8 3/4 housing IS the same as c-body housing 59" flange to flange so the lines should fit. vent bolt might not be same spot on tube ( or maybe I ran into that cut housings down to fit A-bodys)
I got a set of new B-body lines for 16$ off ebay. I was able to make it fit the 67 c-body housing (same as E body) buy stretching it out some to reach the wheel cyls each side.
Dr Diff can make you a new set up IIRC or he makes them long enough you can cut/flare them to fit.
Re: Rear end brake hardline [Re: scratchnfotraction] #2646578
04/18/19 06:49 PM
04/18/19 06:49 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Ive made so many brake lines it aint funny. Piece of cake, not something I would worry about reusing/ transferring from old rear end to new.
Re: Rear end brake hardline [Re: volaredon] #2647259
04/20/19 01:54 PM
04/20/19 01:54 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Or paying for a pre-bent unit.
I have to agree here.
I have mechanical Aptitude.
I can screw up anything.
