rings/sleeves on upper control arm bushings #2632844
03/14/19 10:52 PM
03/14/19 10:52 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
I'm in the process of replacing the dried out rubber bushings in the upper control arms. Pressing them out, I noticed that each side on the rear bushing, there was an extra sleeve/ring/collar that was on the bushing. What was the purpose of this and why were these on the car? Did all cars get them?
Car is a 69 RR.
inherited a 69 roadrunner from my grand pop.
Re: rings/sleeves on upper control arm bushings [Re: fuelishnsilly] #2632890
03/15/19 07:36 AM
03/15/19 07:36 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Most all the cars except 6 cly got those from the factory. It helped to keep that one bushing in because it had more force trying to push it out while in use. Most techs destroyed them in trying to remove them so you seldom see those reinstalled. Someone makes new ones.
Re: rings/sleeves on upper control arm bushings [Re: fuelishnsilly] #2632900
03/15/19 08:17 AM
03/15/19 08:17 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
FSM page 2-11 fig. 16 shows it's used on A bodies with 10" brakes.
Re: rings/sleeves on upper control arm bushings [Re: carteravs] #2632918
03/15/19 09:43 AM
03/15/19 09:43 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have an early set of a-body arms that still have them.. I also have a later big ball joint a-body set that did not have them. However someone else could have removed them years earlier.
If the inside and outside diameters are a common size you could buy some pipe and make your own.
Re: rings/sleeves on upper control arm bushings [Re: Neil] #2632951
03/15/19 10:47 AM
03/15/19 10:47 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: rings/sleeves on upper control arm bushings [Re: hemi71x] #2634075
03/18/19 02:29 PM
03/18/19 02:29 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
They were for fleet vehicles, taxi/police, etc.
Re: rings/sleeves on upper control arm bushings [Re: Montclaire] #2634111
03/18/19 04:21 PM
03/18/19 04:21 PM
Mass
charge70 Offline
charge70  Offline
Mass
My 70 Charger R/T had them as well as my brothers R/T.My Charger 500 did not.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: rings/sleeves on upper control arm bushings [Re: charge70] #2634229
03/18/19 10:06 PM
03/18/19 10:06 PM
Greenwood Lake, NY
Greenwood Lake, NY
Interesting..... so really no rhyme or reason as to why they were installed.
