mig welded
#998313
05/23/11 11:48 AM
05/23/11 11:48 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i was in a plane this past weekend doing loops and all kind of crazy things. hit 3.5 G's. and the one thing i noticed was the plane had mig welds.
another note, as soon as we were done, i had to check what the G's are in a Top Fuel dragster and according to the internet it is 5-6 on launch which must be totally incredible
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: mig welded
[Re: sixpackgut]
#998314
05/23/11 01:13 PM
05/23/11 01:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That plane must have been made out of mild steel... all moly tubing should be tigged... also the decell on the top fuelers has a greater G force than on the acceleration... supposedly 5 Gs on accell and 6 Gs on decell ![](/ubbthreads/images/graemlins/wave.gif)
Re: mig welded
[Re: sshemi]
#998316
05/23/11 01:24 PM
05/23/11 01:24 PM
MR_P_BODY
are you joking or what?? Should be made out of aluminum?
Seen alot of airplane stuff made in moly... a buddy has a copter that is moly ![](/ubbthreads/images/graemlins/wave.gif)
Re: mig welded
[Re: MR_P_BODY]
#998317
05/23/11 01:32 PM
05/23/11 01:32 PM
Posts: 5,080 organ
maximum entropy
organ
the nascar stuff is all wire feed. they have giant, globby welds. the eagle has landed (that's what we say when a huge, ugly weld has been executed).
Re: mig welded
[Re: maximum entropy]
#998318
05/23/11 03:49 PM
05/23/11 03:49 PM
sixpackgut
Charleston
Yes, i also noticed a NASCAR car on display this past weekend with mig welds and chaulked that up to being a display car and really wasnt sure about it
Re: mig welded
[Re: RobX4406]
#998321
05/23/11 05:59 PM
05/23/11 05:59 PM
MR_P_BODY
Aren't cup cars chassis/cages mild steel, no CM in them.
Correct, thats why they mig plus its easier to fix them after a crash ![](/ubbthreads/images/graemlins/wave.gif)
Re: mig welded
[Re: sixpackgut]
#998322
05/23/11 07:00 PM
05/23/11 07:00 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I used to own and fly a 1948 Luscombe 8F Silvaire with a 115 Lycoming Conversion....aluminum structure & skin .... stress rated to +6 -4 g's fun ride ... it was actually the first all-metal small plane produced ![](/ubbthreads/images/graemlins/wave.gif)
Rickster
Re: mig welded
[Re: rickstershemi]
#998323
05/24/11 12:17 AM
05/24/11 12:17 AM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Many small planes are made of chromoly. I think mild steel would be very uncommon due to the weight. Hey, they used to be made out of wood !!!
The welds in roundy-round cars are usually migged because they're mild steel and a mig weld is fine in that application. The weld itself is big and fat because they lower the heat and weld in a circular pattern. The lower heat gives less distortion and maintains the metal integrity while the circular pattern provides the penetration. You will see tig welds but they'll often be used to attach a thick bracket where the amperage required for adequate mig penetration on the bracket would just blow holes in the cage tubing.
Re: mig welded
[Re: Stanton]
#998324
05/24/11 03:06 AM
05/24/11 03:06 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
The FAA allows gas(oxy aceleteneSP?) welding to be used in repairing chromemoly in airplanes, seen it done on a Taylor Craft and a early Piper ![](/ubbthreads/images/graemlins/shruggy.gif) Most of the newer spam cans are all rivited aluminum monoque construction except for the wing spars, landing gear and motor mount cages ![](/ubbthreads/images/graemlins/shruggy.gif) A lot of the earlier airplanes that where fabric covered where wood and steel tubing combined or all of one or the other ![](/ubbthreads/images/graemlins/scope.gif)
Re: mig welded
[Re: Stanton]
#998325
05/25/11 11:17 PM
05/25/11 11:17 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I hate to agrue but as a State certified Union Welder some of these statements I cant agree with... I would of coarse need to look at the weld but I larger weld bead is simply that more weld. Penetration is more or less controlled by heat range... Fact. Now the speed at which one moves will help "under cut" which is when the weld is not held long enough on the sides. Your always pausing on the sides with a Mig and move across the center faster and hold on the sides... Same with arc welding... This keeps the bead from humping up, ties in the sides good just lays down better. Heat dictates everything, how fast you move, Idea is to weld hot as you can and still control the bead in a uniform fashion. I still dont under stand why the sanction body doesnt allow stick/arc welding of the cage. Done properly will be just as strong, actually stronger than MIG.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: mig welded
[Re: MR_P_BODY]
#998327
05/26/11 01:28 AM
05/26/11 01:28 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
That airplane was probably Oxy Acteylene welded, Most steel tube aircraft that were built before 1986 were. Boeing still Oxy hydrogen welded Aluminum until the mid 1990's. One manufacturer mig welded and then had to heat treat the entire airframe in a huge oven. Think of 6'x6'x22' oven that got the tubing to a dull red. When those airplanes crashed, they usually broke in the weldment. ![](/ubbthreads/images/graemlins/hammer.gif) Tig used to be required to be pre and post heated to a dull red with a torch and then left to air cool to normalize 4130. Some will argue this topic but many airplanes are built from 3/4"x.035 wall 4130 normalized tubing. Engine mounts are .049 or .058 wall. They hold a 500 lbs 500+ cubic inch engine that puts out 750 lbft of torque at 2700-3000 RPM. They only get around 235-350 horsepower. All of this on around 8.0-1 compression. I actually read how NHRA got to require tig, the called a welder up and he suggested TIG. They make great welds. Read the attached article. Tim http://www.netwelding.com/Welding%204130.htm
Re: mig welded
[Re: DaKuda]
#998331
05/26/11 01:31 PM
05/26/11 01:31 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
You can very well buy a mig-gun for $200.00 even @ Wal-Mart,but it will not be good enough to weld a roll cage. Not if you want it to hold up if ever in a crash. You can Mig weld a mild steel cage with a good Mig and it will hold if welded right. You run a bead down hill (welders know)with a mig,it won't hold!!!! Like someone said earlier you can buy a $200.00 arc (220 amp)and weld any M.S. cage and it will hold better than any mig weld.Take you forever to weld it,but will give you a stronger weld. I was a supervisor in the weld-bay @ Varco-Pruden for 14 yrs. been a welder for 25+ yrs. BEWARE of who you trust to do any welding on your Race-Car. ![](/ubbthreads/images/graemlins/Twocents.gif) A poor weld is about like sticking bubble-gum on your cage or what ever you have welded,just because it is stuck on it does not meen it will hold. ![](/ubbthreads/images/graemlins/grin.gif)
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: mig welded
[Re: DaKuda]
#998332
05/26/11 02:38 PM
05/26/11 02:38 PM
MR_P_BODY
So what about the millions of us who can MIG weld correctly...its absolutely strong enought then.
Tig welding on moly is to keep the heat down(a very concentrated heat point) because your welding on thinner material ![](/ubbthreads/images/graemlins/wave.gif)
