Page 9 of 14 1 2 7 8 9 10 11 13 14
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997935
05/29/11 04:22 AM
05/29/11 04:22 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
and here it is bolted in (With some major sheetmetal removal from the transmission tunnel!)
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997936
05/29/11 04:23 AM
05/29/11 04:23 AM
QLD Australia
QLD Australia
anothershot:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997937
05/29/11 04:24 AM
05/29/11 04:24 AM
QLD Australia
QLD Australia
new bell/firewall clearance:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997938
05/29/11 04:26 AM
05/29/11 04:26 AM
QLD Australia
QLD Australia
another shot/T56 M in place:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997939
05/29/11 04:27 AM
05/29/11 04:27 AM
QLD Australia
QLD Australia
inside the car- this is the impact on the trans tunnel--
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997940
05/29/11 04:29 AM
05/29/11 04:29 AM
QLD Australia
QLD Australia
transmission tunnel cut other side--
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997941
05/29/11 04:31 AM
05/29/11 04:31 AM
QLD Australia
QLD Australia
with old dash frame, steering column etc removed.
Note I patched the bulkhead as I will be running Vintage Air Gen IV climate system, will all be up/inside the dash frame.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997942
05/29/11 04:33 AM
05/29/11 04:33 AM
QLD Australia
QLD Australia
nest step bright purple cardboard to cut a template for new tunnel
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997943
05/29/11 04:34 AM
05/29/11 04:34 AM
QLD Australia
QLD Australia
AND ..done:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997944
05/29/11 04:35 AM
05/29/11 04:35 AM
QLD Australia
QLD Australia
finished tunnel 2/2:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997945
05/29/11 04:38 AM
05/29/11 04:38 AM
QLD Australia
QLD Australia
here's a cheeky pic of something I'll provide more detail of later
yes that's an e-Body dash. We stitched a B & E body dash frame together... more to come on this later
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997946
05/29/11 04:40 AM
05/29/11 04:40 AM
QLD Australia
QLD Australia
Ok, here's some of the strengthening made to support the x-member. The crossmember had to be cut to make room for the bulky transmission.
We made a higher support to keep the strength, this is VERY thick steel 1/4 in., and the lower/mount support ties it together very rigidly.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997947
05/29/11 04:41 AM
05/29/11 04:41 AM
QLD Australia
QLD Australia
here's first shot of lower mount, also made entirely out of 1/4in steel.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997948
05/29/11 04:43 AM
05/29/11 04:43 AM
QLD Australia
QLD Australia
and another of the mount fab:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997949
05/29/11 04:47 AM
05/29/11 04:47 AM
QLD Australia
QLD Australia
finished transmission install.
Angles perfect,
Note the Poly-lock trans mount & new Driveshaft.
Custom made:
Mark Williams Chrome Moly, 1350 Strange Billet Steel trans Yoke. Very Nice peice
I looked at fabricating a two-peice shaft with a centre bearing but the consensus was maintaining alignment with the centre bearing throughout the power & operating range would have caused failure. Torque will be huge, so not worth the risk.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997950
05/29/11 05:06 AM
05/29/11 05:06 AM
QLD Australia
QLD Australia
So I'll make a small detour here and show how the brake m/cyl & pedals are set up.
Here;s the master cylinder & Hydraboost system:
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997951
05/29/11 05:08 AM
05/29/11 05:08 AM
QLD Australia
QLD Australia
another pic of m/c
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997952
05/29/11 05:10 AM
05/29/11 05:10 AM
QLD Australia
QLD Australia
installed (incl. making a plate to mount to firewall):
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997953
05/29/11 05:13 AM
05/29/11 05:13 AM
QLD Australia
QLD Australia
Also installed the clutch m/cyl at this time. Made up a billet aluminium bracket to support the cylinder. Great kit, supplied by American Powertrain. Good to deal with. speedy.priced better than competitors.can order straight from website.
Re: My 68 Hemi Charger Project -a little different [Re: Keith Black®] #997954
05/29/11 05:14 AM
05/29/11 05:14 AM
QLD Australia
QLD Australia
another of clutch m/c mounted:
