Re: OK.............Let's see a show of hands.
[Re: VernMotor]
#997557
05/23/11 10:30 AM
05/23/11 10:30 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
That grinder would be great when cutting Tool Steel rings for large gaps on nitrous engines. I have actually had to use a cut off wheel to get close then start grinding with the ring grinder.
Buy a new set of rings due to one being a little big??? How big?? I would have probably used that ring in a hole I new got hotter than others.
Leon
[Re: efisixpack]
#997558
05/23/11 07:20 PM
05/23/11 07:20 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
who has the best tool for grinding ring? Also, what is the best way to debur rings?
ABS has the best ring filer that I have used and know of, it has a rotating deburr brush already on it.
[Re: LSP]
#997559
05/24/11 12:11 AM
05/24/11 12:11 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
I bought this Proform ring filer several years ago, it makes gapping rings a lot easier and quicker 1 to 2 hours on the top moly rings depending on the application and how precise I wnat the gaps, 40 minutes to 1 hr. to do the softer 2nd iron rings, again depending on how close they end up being, .0010 requires some stoning on the last fittings and within .001 to .003 only needs the wheel on the girnder How many of you are checking the ring side clearances and back spacing? Oops, forgot the picture
[Re: dartman366]
#997562
05/25/11 12:08 AM
05/25/11 12:08 AM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
I don't know what is worse,, filing ring's or spiro-loc's.
I like doing both
