Re: Wrecked the car today! **Diag** Pics
[Re: PC-CHARGER]
#997307
05/30/11 10:25 AM
05/30/11 10:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You're correct. The valve bodies that do not have low band apply must not have a trans brake. So that would indicate that all trans brake valve bodies that utilize the front clutch to activate the trans brake are also low band apply units. I never realized this until you mentioned the two clutches applied. Thanks
As for the brake applying the front clutch and the rear band, are you sure of this or does the brake simply apply the front clutch and the band is applied through the manual valve movement? I guess an easy way to check would be to have the trans in neutral and push the brake button. If the car backs up, then it would indicate that the brake applies both but if is does nothing, then it would only be applying the front clutch, correct?
Mine(non low band apply)wont do anything if in neutral and hitting the button.... T/A manual reverse pattern
[Re: PC-CHARGER]
#997309
05/30/11 10:48 AM
05/30/11 10:48 AM
Posts: 20,657 in a cattle trailer down by th...
Guitar Jones
My T/A brake does nothing in neutral, as I said it's claimed to have a timed rear band release. After the front clutch is released the rear band can be released anytime before the 1-2 shift. My VB has no 1st gear braking so the valvebody is not applying the rear band, the brake portion is doing it. As I said though I've never really studied it to see how it works, as long as it worked I just wasn't that curious. This episode though has me thinking.
[Re: PC-CHARGER]
#997310
05/30/11 10:56 AM
05/30/11 10:56 AM
MR_P_BODY
Thanks Mike, but this raises yet another question. You say yours is a non LBA valve body with a brake, yet what Stephen pointed out is that if you don't have the band on and you press the brake button with the manual lever in a forward postion, you basically have high gear since the sprag does not hold when both clutches are applied. I believe he is correct but if your valve body is indeed a non LBA with a brake, then I'm not sure what to assume. I thought the T/A units utilized the front clutch as the holding member but maybe not?
In mine you have to have the shifter in low gear for the brake to work and when you manually have the shifter in low you are applying the low band if I'm not mistaken
[Re: MR_P_BODY]
#997311
05/30/11 11:34 AM
05/30/11 11:34 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Just thinking out loud, but never having a T/B in a Mopar trans (just the glide)....is there a pro-brake & non-pro-brake offering for Mopars...???? Asking because in the glide....you only need the button for reverse with a pro-brake Rickster
[Re: rickstershemi]
#997312
05/30/11 11:42 AM
05/30/11 11:42 AM
MR_P_BODY
Rickster
Sorta... there is a low band apply and a non low band apply... I run the non low band apply and you dont need the button BUT to my understanding the low band apply version you need to hit the button for reverse... they offer a faster release version also for the pro tree
[Re: MR_P_BODY]
#997313
05/30/11 11:55 AM
05/30/11 11:55 AM
Guitar Jones
There are many different manufacturers offering different valve bodies. The T/A was one of the first to use an internal solenoid release. Early Lamb versions had an external solenoid and didn't work all that well. Supposedly the T/A VB that I have, an early version, is not good for a pro tree. I can however cut .4teen lights with it if I don't use a two step. Otherwise it's a .500 tree brake.
Since then there are many others with various features, Griner, JW, TranzAct, Hipster, TCI and so on.
[Re: Guitar Jones]
#997315
05/30/11 11:59 AM
05/30/11 11:59 AM
Guitar Jones
BTW the brake I'd like to have would be the clean neutral VB. The shift pattern is P, R/N, (push button for reverse) 1, 2, 3, N. Since I use an automated shifter I'd have to modify that as well as spend the $700 for the V/B. That's not going to happen unless I win the Lottery.
[Re: MR_P_BODY]
#997316
05/30/11 12:00 PM
05/30/11 12:00 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Rickster
Mike I had a griner NON LBA TB, and I had to use the button for reverse. Don
