Re: Wrecked the car today!
[Re: aarcudaden]
#997272
05/23/11 01:29 AM
05/23/11 01:29 AM
Posts: 903 Saskatchewan, Canada
cudabin
Glad you are OK.
I am sure the car will look good again, but main thing is you lived to tell the tale.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: CRT]
#997276
05/23/11 11:35 AM
05/23/11 11:35 AM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
Great to hear you are ok, Lonnie. I'm sure your driving ability saved what could have been a worse wreck. I know times are tough, so don't hurry it back to health the wrong way(which you would never do anyway). Good luck.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: wheelsup68dart]
#997285
05/24/11 08:40 AM
05/24/11 08:40 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Before a wildfire spreads and anyone wonders about the facts. My Saturday morning time run at the Mo-Power classic event ended in disaster. After making what I thought was an outstanding run thru the 1/4 mile 9.57@ 138.17(New best MPH), after I lifted at the stripe and went for the brakes my car went into what I would describe as engine braking(jake brake) and began to decelerate hard, had enough time to look to see oil pressure good and then rear tire lock up @ approx 90mph car was briefly perpendicular to the retaining wall before it rotated a little more and left front into wall bouncing left rear into wall. Left front fender is a loss and quarter gonna need extensive work, but did not strike the wheels and all frame work okay, did not even bounce me around in the seat. I am sure there are some that took pictures, and it is okay to post them, but long story short I am just fine, now need to find out the root cause. Suspect trans failure of some sort and there was trans fluid leaking after I came to a stop. Thanks to everyone that checked on me, and I WILL BE BACK!
Sorry to hear you kissed the wall, and I see here on Moparts that you have gotten 39 man hugs but no one asking if they can help you out. I always help out my customers when they crash my fiberglass parts. Give me a call here at Sled City Fiberglass 1-614-875-0369
