Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: moparrulzzz] #992793
05/16/11 04:28 AM
05/16/11 04:28 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If you do dimple it, won't it be hidden by the TB?
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: jbc426] #992794
05/16/11 09:14 AM
05/16/11 09:14 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
You'll get about a 1/4" of sag out of that right mount in a couple of months.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: pinkduster] #992795
05/16/11 10:39 AM
05/16/11 10:39 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I doubt it with poly-loc's
I have the Schumacher Poly Lock mounts
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: DJVCuda] #992796
05/17/11 12:05 AM
05/17/11 12:05 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Uh, I have Schumacher Poly Lock mounts and after a couple months and maybe 20 passes down the track, I had to make some shims for my sagged right side mount to keep the oil pan (aftermarket) off the centerlink. My next move will be to solids.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: pinkduster] #992797
05/17/11 10:29 PM
05/17/11 10:29 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Well I had a long conversation with TTI tonight. I explained what was going on, parts I was using and gave him the measurments that they say needs to be achieved so the headers will fit. They say there is no reason for the contact. He doesn't think it's the mounts.
They are now thinking maybe a 440 flange was welded to a 383 set of pipes. Due to my engine seeming to be to high.
I am keeping my fingers crossed that that is the case. They are calling me back tomorrow with some measurments for me to check.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: moparrulzzz] #992798
05/18/11 04:14 AM
05/18/11 04:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This doesn't sound right. The 383 and 440 use the same heads, same exhaust port sizes, same bolt pattern....
ALL the headers individual pipes make a 90 degree bend toward the flange, so the flange itself has no angle. They are separate pieces with a flat face.
I have heard of several cases where the header manufacturers are adamant that their products are NOT to blame for fitment issues.
YOUR car has worn motor mounts.
YOUR car must have been in a wreck.
YOU must not know what you are doing.
YOUR car has power steering, an automatic OR a 4 speed, Your radio is too loud. The instructions are in Spanish.......
NO company wants to admit that their products are faulty.
I have a friend that is trying to install Hedmans in a 73 Dart 360. Fitment problems galore on the drivers side. Customer service was of no help.
The TTI pipes are some of the best made, so to have problems with them means that something IS amiss here. If the engine is mounted correctly, the trans mount bolts up as it should, the car has never been wrecked, the torsion bar isn't bent, the lower control arm bushing isnt shredded, (Allowing the LCA to shift away from its correct position)Then...... maybe the header WAS built wrong.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: Kern Dog] #992799
05/18/11 01:33 PM
05/18/11 01:33 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Don't forget - "If you turn up the radio you can't hear the rattle".
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: GomangoCuda] #992800
05/18/11 01:48 PM
05/18/11 01:48 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Headers can be built specifically for a B or an RB:Case in point. I had a set of Pro-Parts headers that DIDNT fit a 383, but fit a 440 just fine. The 383 hit the header at the pan rail, the 440 didnt. So not all B/RB headers are the same, but should be! The flange MIGHT be specific if the kickout is less (smaller radii for the 90 bend out the port) for a 440 than a 383, that makes a little sense as the 440 head is farther outboard than the 383 and space may be taken into consideration when they design them (a larger radii is always better than a small radii when it comes to bends)
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: pishta] #992801
05/18/11 02:55 PM
05/18/11 02:55 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
"This doesn't sound right. The 383 and 440 use the same heads, same exhaust port sizes, same bolt pattern...."
An RB block sets the heads farther up and significantly wider out than a B motor.
The 440 is an RB = raised block, so the heads do sit farther away from the crank centerline. That can make a measurable difference in the length of pipe drop needed to get them down and away from the torsion bar in some applications, like B & E bodies.
The flange and shapes of the tubes coming out of the head are the same for 383 & 440, but the tube drop length to the collector is different. The collector essencially sits lower than a 383 collector on some brands, like TTI's. The amount lower is roughly equal to the difference in the blocks between RB's & B blocks.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: pishta] #992802
05/18/11 03:06 PM
05/18/11 03:06 PM
the house on the left.
cogen80 Offline
cogen80  Offline
those pro parts on a 383 should have ht the steering also. its close with a 440 and with the lower 383 i would think they would hit.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: jbc426] #992803
05/18/11 03:19 PM
05/18/11 03:19 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thanks. I know all of that. MY point was that the 3/8" FLAT flange should be the same for ALL the TTI big block headers. To blame the fitment on the flange isn't sensible. Maybe the OP had a communication misunderstanding with the TTI people. The bends up near the flange would need to be shorter and tighter for the same headers to have the same exact clearance down below.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: Kern Dog] #992804
05/18/11 06:56 PM
05/18/11 06:56 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yah, I wonder what it will turn out to really be.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: jbc426] #992805
05/18/11 10:29 PM
05/18/11 10:29 PM
Mansfield,Ohio
Mansfield,Ohio
Let me be clear on my earlier post about a 440 flange being welded to a set of 383 pipes.
TTI stamps the flanges with engine size/tube size...mine 440178.
They are thinking a flange STAMPED 440178 made it into the line when they were assmbling headers for a 383 and was not caught. Hence being sold as a 440 header when in fact it was for a 383.
TTI website says their 383/400 and 440 headers are different.
TTI sent me some measurements to check, I did and called them in and it further leads them to believe this.
My passenger side header is now boxed up and they are paying shipping to make 100% sure.
If it is indeed a 383 header they are sending me a correct 440.
We will see!!
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: moparrulzzz] #992806
05/18/11 10:39 PM
05/18/11 10:39 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
WOW
Good for em to check into it. I've gone through plenty of right box/wrong part fiascos myself
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: A990] #992807
05/18/11 10:58 PM
05/18/11 10:58 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
i think your car is haunted. it does not want to be finished. it does not want to leave your warm comfortable garage.
Re: TTI's, Remflex Gaskets and Torsion bar hitting header [Re: 2abodymcodes] #992808
05/18/11 11:30 PM
05/18/11 11:30 PM
Mansfield,Ohio
Mansfield,Ohio
Starting to think that myself, go from one problem to another!!!
