Re: Raybestos 11.75" / 7038R = junk?!
[Re: 6o4o]
#991754
05/20/11 10:40 PM
05/20/11 10:40 PM
Posts: 28,096 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A rough measurement shows about 3/8" thick. You may want to take a tiny drill bit and make a hole straight through the wall of the hub. You can poke a wire through it and measure it that way. A tiny hole will not remove enough metal to be noticeable in balance or strength of the rotor.
