okay guys its sunday & raining again
so as promised I have news If i turn flashers on all works great. if I try blinkers seperate the drivers side front dash,fender &grill light have no power rear works great so it sounds like to me either connection at harness from column or blinker switch? I do know the lever feels incorrect & if you move it a little the rear will not flash but the fronts never show sign of life from playing with lever so It is probably the switch or just loose inside? what do you guys think
Sorry for all the jibber
but please give me your input
