Re: Worst repro part ever done?
[Re: ChallengerRag]
#989712
05/26/11 10:30 PM
05/26/11 10:30 PM
Package trays that don't have the correct number of cutouts. I mean seriously. If you're gonna repro an easy part like that, how hard is it to do it exactly as factory?
[Re: ]
#989713
05/26/11 10:46 PM
05/26/11 10:46 PM
Posts: 12,439 Warren, MI
71TA
Warren, MI
It's ECS doing these correctly now?
[Re: 71TA]
#989717
05/27/11 07:54 AM
05/27/11 07:54 AM
Yes. I got one from them a few years ago when I found out there was a difference. Thanks to ECS for their intense attention to detail.
[Re: intragration]
#989720
07/15/11 10:23 AM
07/15/11 10:23 AM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Now all I need are the rear trunk/quarter trim pieces, the Gran Coupe and '72-'74 style. These were available last year, can't seem to find them anymore...
BE&A makes them.
Are your quarters original? The old repro quarters had the side marker holes stamped wrong. My replacement side markers (from Herb's) fit the new Goodmark quarters perfectly.
[Re: burdar]
#989721
07/15/11 12:28 PM
07/15/11 12:28 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Factory original on L, PST on R.
PST, Performance Suspension Technology of New Jersey, ‘your musclecar specialist’, said, “We’ve sold thousands of these strut rod bushings, and you are the first one to complain they are too big. Why don’t you just use a castle nut and a cotter pin? I never heard of using a roll pin. You mean the original design didn’t use a castle nut?”
[Re: phantomx]
#989725
07/29/11 01:09 PM
07/29/11 01:09 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
sherman/cross canada rocker panels.... one size fits all makes and models !
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: smac77]
#989726
07/31/11 03:34 AM
07/31/11 03:34 AM
Posts: 392 Mississippi
lahatte
Mississippi
Wow! You guys are destroying my faith that there are good parts available to build my latest project. All this bad news is sad, but good, to know about.
As for bad parts, back in the mid-80s I ordered a pair of 'patch panels' for the rear quarters for a cuda. They were the entire quarter panel length, covering the portion below the body line. And get this... these things were made on a sheet metal brake! And the lower rear area was simply a roll of metal, with a split between it and the rest of the panel so the body guy could mimic the curved contour at the bottom. Cleaver, no? I couldn't believe it when I saw them. Fortunately, they were slightly mashed in shipping, so at least I didn't have to pay that.
More recently, I got some front torque boxes. They don't fit, as the vertical edges are not parallel between the inside and outside. See picture. The "Made in USA" picture shows what should be correct.
[Re: wally426ci]
#989728
07/31/11 11:28 PM
07/31/11 11:28 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Penstar Reproduction
Go noooooo further than those 2 words.. I honestly do not know how this outfit is still in business...The 72 RR grille mounting kit does not have one bolt or screw similar to the originals..The plastic washers are nice though..
