Page 2 of 3 1 2 3
Re: carter afb...where to buy? [Re: Neil] #98943
08/03/08 05:06 PM
08/03/08 05:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That's what I was thinking, I noticed the lack of a freeze plug on the ends of the heads and figured they were something different. The early iron W2's have the freeze plugs.
Re: carter afb...where to buy? [Re: ScottSmith_Harms] #98944
08/03/08 07:08 PM
08/03/08 07:08 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
So, anyone know if a 1969 ramcharger air cleaner will fit on an edelbrock 650 carb?
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: carter afb...where to buy? [Re: new bee] #98945
08/03/08 07:16 PM
08/03/08 07:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I once had the 440 oval air cleaner and I could have swore that I test fitted it on the spare 625 afb I have before I sold it. I don't recall a problem, but it was a long time ago....
I have the carb(s) so if somebody wants to supply the air cleaner hole diameter I can tell if it will work or not.
Re: carter afb...where to buy? [Re: Neil] #98946
08/03/08 07:40 PM
08/03/08 07:40 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
That would be excellent, Neil. Thanks to whoever comes up with that diameter!
*1965 Porsche 356C
*2004 Mini Cooper S
Re: carter afb...where to buy? [Re: new bee] #98947
08/03/08 07:42 PM
08/03/08 07:42 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
yes it will
Re: carter afb...where to buy? [Re: JohnRR] #98948
08/03/08 07:55 PM
08/03/08 07:55 PM
mo. usa
U
ukieone Offline
ukieone  Offline
U
mo. usa
yep,have one on the r/t now. looking for an 800.
Re: carter afb...where to buy? [Re: ukieone] #98949
08/04/08 11:03 AM
08/04/08 11:03 AM
dogdays Offline
dogdays  Offline
The AVS is a very good carb and I'd have it rebuilt. The carb number is usually stamped into the edge of the passengers side front foot.
To clarify something about the various makers of the carbs, Carter went out of business. Edelbrock bought the RIGHTS and probably the patterns to make the carb with their name on it, their carb is built by Weber.
Federal-Mogul got I believe the whole Carter empire and made the AFBs for a few years, then quit production. So it was F-M that killed the Carter AFB.
R.
Re: carter afb...where to buy? [Re: new bee] #98950
08/04/08 11:53 AM
08/04/08 11:53 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
in the mid 60's (65? 66?) the carter 4bbls went from a smaller top diameter to the common 5 1/4" top diameter
2017 Grand Cherokee Overland
Re: carter afb...where to buy? [Re: patrick] #98951
08/04/08 11:56 AM
08/04/08 11:56 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
as far as i can tell that didn't change till 68 .
that aside, it sounds like he has the air cleaner already on it and he is calling it the wrong carb
Re: carter afb...where to buy? [Re: JohnRR] #98952
08/04/08 12:33 PM
08/04/08 12:33 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
OK, I ordered the Edelbrock carb from my local parts place. I can pick it up this evening. Earlier today, I talked to Summit's tech people and they said the top diameter is 5-1/8".
Will this still work with the stock air cleaner?
*1965 Porsche 356C
*2004 Mini Cooper S
Re: carter afb...where to buy? [Re: new bee] #98953
08/04/08 12:52 PM
08/04/08 12:52 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
did you miss the part in this thread were it was said ....
YES IT WILL FIT
the only thing you may have to do is bend up the 2 small locatiing tabs at the rear of the carb opening on the air cleaner base , stock carbs have notches to orient the air cleaner and keep it from turning .
Re: carter afb...where to buy? [Re: JohnRR] #98954
08/04/08 12:56 PM
08/04/08 12:56 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
yeah, john, but will it fit???
*1965 Porsche 356C
*2004 Mini Cooper S
Re: carter afb...where to buy? [Re: new bee] #98955
08/04/08 12:56 PM
08/04/08 12:56 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
*i totally crack myself up*
*1965 Porsche 356C
*2004 Mini Cooper S
Re: carter afb...where to buy? [Re: new bee] #98956
08/04/08 03:07 PM
08/04/08 03:07 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
One more question!
Wiull this carb fit on a stock intake manifold, without using any special adapters?
*1965 Porsche 356C
*2004 Mini Cooper S
Re: carter afb...where to buy? [Re: new bee] #98957
08/04/08 03:17 PM
08/04/08 03:17 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
One more question!
yes.
Re: carter afb...where to buy? [Re: AdamR] #98958
08/04/08 05:17 PM
08/04/08 05:17 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You may need the chrysler kickdown adapter/throttle linkage part that they sell seperately. When I bought my 800 avs in the picture I posted earlier I had to go back and pick up the adaptor thingy that bolts onto the existing linkage.
Oh, and don't try taking the carb from the box and bolting it right on the car. I have put 5 or 6 of them on and from my experience they are just thrown together. You MUST take the lid off and check the float drop in both directions and make sure the jets are tight. Turn the two air mixture screws all the way in and then back them out 2-1/2 - 3-1/2 turns. This will get it close enough that it should run and you can fine tune it with a vacume guage later.
Also if you bought the electric choke model there is a fast idle screw hidden way down on the linkage. The last carb I put on this screw was way out of adjustment and when I went to start the engine the rpm went sky high instantly. Scared the crap out of me and not good on the engine.
Re: carter afb...where to buy? [Re: Neil] #98959
08/04/08 05:32 PM
08/04/08 05:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Good advice
Re: carter afb...where to buy? [Re: Neil] #98960
08/04/08 05:52 PM
08/04/08 05:52 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
he will absolutely need the adaptor or else the connecting the throttle cable will be an issue
Re: carter afb...where to buy? [Re: ScottSmith_Harms] #98961
08/04/08 05:52 PM
08/04/08 05:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
This is the linkage adapter you need to locate.
https://board.moparts.org/ubbthreads/show...e=0#Post4595583
Re: carter afb...where to buy? [Re: Neil] #98962
08/04/08 06:00 PM
08/04/08 06:00 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
Will this adaptor work with on a 4sp car?
*1965 Porsche 356C
*2004 Mini Cooper S
Page 2 of 3 1 2 3
