Re: carter afb...where to buy?
[Re: ScottSmith_Harms]
#98944
08/03/08 07:08 PM
08/03/08 07:08 PM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
So, anyone know if a 1969 ramcharger air cleaner will fit on an edelbrock 650 carb?
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
[Re: Neil]
#98946
08/03/08 07:40 PM
08/03/08 07:40 PM
new bee
Richard Cranium
Richard Cranium
portland or
That would be excellent, Neil. Thanks to whoever comes up with that diameter!
[Re: new bee]
#98947
08/03/08 07:42 PM
08/03/08 07:42 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
yes it will
[Re: patrick]
#98951
08/04/08 11:56 AM
08/04/08 11:56 AM
JohnRR
A gulag near you.
in the mid 60's (65? 66?) the carter 4bbls went from a smaller top diameter to the common 5 1/4" top diameter
as far as i can tell that didn't change till 68 .
that aside, it sounds like he has the air cleaner already on it and he is calling it the wrong carb
[Re: JohnRR]
#98952
08/04/08 12:33 PM
08/04/08 12:33 PM
new bee
Richard Cranium
Richard Cranium
portland or
OK, I ordered the Edelbrock carb from my local parts place. I can pick it up this evening. Earlier today, I talked to Summit's tech people and they said the top diameter is 5-1/8". Will this still work with the stock air cleaner?
[Re: new bee]
#98953
08/04/08 12:52 PM
08/04/08 12:52 PM
JohnRR
A gulag near you.
did you miss the part in this thread were it was said ....
YES IT WILL FIT
the only thing you may have to do is bend up the 2 small locatiing tabs at the rear of the carb opening on the air cleaner base , stock carbs have notches to orient the air cleaner and keep it from turning .
[Re: JohnRR]
#98954
08/04/08 12:56 PM
08/04/08 12:56 PM
new bee
Richard Cranium
Richard Cranium
portland or
yeah, john, but will it fit???
[Re: new bee]
#98955
08/04/08 12:56 PM
08/04/08 12:56 PM
new bee
Richard Cranium
Richard Cranium
portland or
*i totally crack myself up*
[Re: new bee]
#98956
08/04/08 03:07 PM
08/04/08 03:07 PM
new bee
Richard Cranium
Richard Cranium
portland or
One more question!
Wiull this carb fit on a stock intake manifold, without using any special adapters?
[Re: new bee]
#98957
08/04/08 03:17 PM
08/04/08 03:17 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
One more question!
yes.
[Re: Neil]
#98959
08/04/08 05:32 PM
08/04/08 05:32 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh, and don't try taking the carb from the box and bolting it right on the car. I have put 5 or 6 of them on and from my experience they are just thrown together. You MUST take the lid off and check the float drop in both directions and make sure the jets are tight. Turn the two air mixture screws all the way in and then back them out 2-1/2 - 3-1/2 turns. This will get it close enough that it should run and you can fine tune it with a vacume guage later.
Also if you bought the electric choke model there is a fast idle screw hidden way down on the linkage. The last carb I put on this screw was way out of adjustment and when I went to start the engine the rpm went sky high instantly. Scared the crap out of me and not good on the engine.
Good advice
[Re: Neil]
#98960
08/04/08 05:52 PM
08/04/08 05:52 PM
JohnRR
A gulag near you.
You may need the chrysler kickdown adapter/throttle linkage part that they sell seperately. When I bought my 800 avs in the picture I posted earlier I had to go back and pick up the adaptor thingy that bolts onto the existing linkage.
he will absolutely need the adaptor or else the connecting the throttle cable will be an issue
[Re: Neil]
#98962
08/04/08 06:00 PM
08/04/08 06:00 PM
new bee
Richard Cranium
Richard Cranium
portland or
Will this adaptor work with on a 4sp car?
