Re: Alternator mounting w/W9's and a Crank Trigger w/ FAST
[Re: MR_P_BODY]
#988201
05/10/11 11:02 PM
05/10/11 11:02 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
So you mounted it to the cast alluminum fuel pump mounting holes on the original timing cover? Pbody
[Re: Leon441]
#988202
05/10/11 11:26 PM
05/10/11 11:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes... I made a steel bracket that spans past both bolt holes, it drops the upper pivot to about 1 1/2" below the pump bolt holes... I'll see if I can get a pic tomorrow... I've had it on 3 engines for the last 12 years now... no problems at all
[Re: ADakotaRTGuy]
#988205
06/02/11 06:33 PM
06/02/11 06:33 PM
MR_P_BODY
Would you be willing to make another one? I can pick up the timing cover pretty easily if you can.
I can build another... would be no problem
[Re: ADakotaRTGuy]
#988206
06/02/11 11:12 PM
06/02/11 11:12 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Jones Belt drive in ottsville pa makes one.They run it with a gilmer belt looks realy trick mounts level with crank.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: MR_P_BODY]
#988207
06/03/11 03:15 AM
06/03/11 03:15 AM
Posts: 193 MD
ADakotaRTGuy
MD
I am assuming that the lower hose won't work on the passenger side?
[Re: ADakotaRTGuy]
#988208
06/03/11 10:09 AM
06/03/11 10:09 AM
MR_P_BODY
My lower hose is on the drivers side... using a electric pump it has the threaded hole on either side for the hose nipple
[Re: 1967dartgt]
#988210
06/03/11 01:05 PM
06/03/11 01:05 PM
Posts: 193 MD
ADakotaRTGuy
MD
Is it on their page? I did not see anything on there.
