help, i'm at my wit's end... fuel issues?
#988148
05/08/11 04:38 PM
05/08/11 04:38 PM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
so my new 500" low deck runs fantastic, nice crisp throttle response, feels like gobs of power, temp stays at 180 with the HHR fan and alum rad, good oil pressure but I can't even make it to the gas station to fill up because of this weird problem. once the car is fully warmed up and i get about 2-3 blocks away from home the car starts wanting to die when idling in gear, if i throw it in park it recovers and runs perfect and as long as i'm driving it's fine it's just idling in gear at a stop. I put a small pressure gauge at the carb and was running a brand new carter hp pump and the needle would bounce between 11-15 psi till it got hot then sit at 6psi and the clear plastic filter before the carb would start out full then it gets hot and would dry up so i put back my old fuel pump that worked perfect for years, same thing, starts out full then goes almost empty when it gets to operating temp, i can see a small trickle of gas enter the filter but it runs fine in park or neutral. new tank, new pickup, 3/8 steel line (not plugged) all new rubber sections, 2 different fuel pumps, brand new holley ultra hp 950, AAAARRRRGGHHH, i don't know what to do, is the filter supposed to be full of fuel? i would think so or am i missing something, sorry so long, HELP i want to drive
Re: help, i'm at my wit's end... fuel issues?
[Re: dirtybee]
#988149
05/08/11 05:18 PM
05/08/11 05:18 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I had a fuel pump push rod drive me crazy for a while,,,it was worn pretty bad,,,,not sure if that would cause the symptoms you describe,,, ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Pretty easy to check and see if the length is correct,,and not worn down,,,,
[Re: dirtybee]
#988151
05/08/11 05:55 PM
05/08/11 05:55 PM
Posts: 7,506 Az
Crizila
Az
Things that come to mind: Fuel is boiling in the carb. Float levels are too low. Tank is not venting. Vacuum leak.
Fastest 300
[Re: Crizila]
#988153
05/08/11 07:21 PM
05/08/11 07:21 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I would rule out the pump rod, because if it was warn, it wouldn't change things from hot too cold, I would look into a vapor/venting problem, if it runs/idles good when cold & the filter has alot of fuel in it, but drains when its warm, somethings not right. another thing is, you say the pressure is up to 11-12 when cold, but drops too 6 & holds steady when warm, this shouldn't happen, when it does happens, you need to take off the sight screws on the carb & see if the bowls are low on fuel, if so, then you found the idling problem, if it drops too much in the bowl it'll screw up the metering & idling when become an issue, fuel pressure will drop also if there is air trapped from a bad venting system. Have you tried another guage to rule that out?
[Re: dirtybee]
#988154
05/08/11 08:17 PM
05/08/11 08:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Make up a fuel tank that you can hang from the hood so it gravity feeds... see if it runs on that... then do a flow test on your pump and tank set up... at least then you can say weather its a carb or supply issue ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dirtybee]
#988156
05/08/11 08:35 PM
05/08/11 08:35 PM
MR_P_BODY
but it runs in park or if i'm driving in gear just when i'm stopped, like at a red light and in gear. the weird thing is it runs like this with an empty filter but the gauge reads 4-5 psi steady now that i have my old pump on it. i'll put a link of the new mill running with the other new carter hp pump for gtx dude.
Load it up in gear and see what it does... bring it up to about 2000 rpm in gear(with the brakes on) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Chris'sBarracuda]
#988161
05/08/11 10:27 PM
05/08/11 10:27 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
By watching the Video, its easy to see that the Bypass is hanging on the electric fuel Pump.. Is this a Holley HP version? They are bad about doing this.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#988162
05/08/11 10:31 PM
05/08/11 10:31 PM
Bob_Coomer
Rock Springs
also looks like the fuel pressure is spiking to 12+PSI at times. have you noticed fuel flowing from the boosters at idle? It might be pushing through at idle cause the fuel pressure is highest then, it would be more manageable down the road not to load up.. Fuel pressure shouldn't be much more than 8 PSI... Either your fuel pump is junk, or its the regulator.. Its shouldn't be dancing around on the gauge like that.. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: dirtybee]
#988172
05/09/11 12:04 PM
05/09/11 12:04 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
If the fuel level is high and the float is sunk it is either bent or full of fuel. Black ones don't fuel log that I have seen. Once the needle and seat is adjusted too much it does not close any more. Kinda goes past center. You may need a fuel regulator. Black ones are bad for the tang bending! But it can be bent back up and start over.
I like to hold bowl upside down and adjust till float is centered kind duplicates the fuel floating it!
If you bought a liquid filled fuel gauge toss it!!
Re: help, i'm at my wit's end... fuel issues? UPDATE
[Re: Dodgem]
#988173
05/20/11 01:24 PM
05/20/11 01:24 PM
dirtybee
Toronto, Canada
ok, i'm a little embarrassed and still a bit confused. it is a new carb and it seems it was the float level causing it to die in gear idling (oops, feel like a bit of a dummie), i took the floats out and indeed they needed to have the tang bent back on them so i could get a good fuel level in the bowl (thanks dodgem, good call). so the car runs ok now BUT....the filter still starts out full and after 15-20 minutes is almost empty with just a trickle of fuel in the inlet, the car runs good and the gauge reads 4-5 psi constant, it just has no fuel in the filter????? should i just consider this normal? thanks to everyone for the help, i just wanted to share what i found but if anyone can explain if the empty filter thing is normal or not i would love to hear your thoughts, again it's an old mechanical pump on it now with no regulator.
[Re: dirtybee]
#988175
05/21/11 08:49 AM
05/21/11 08:49 AM
MR_P_BODY
curious about the empty filter thing?
The only reason its empty is lack of flow... understand that its common to see it 1/2 full... this is due to the air above the inlet and outlet doesnt have a way to escape(if its on a horizontal) if its mounted vertical it should fill ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#988176
05/21/11 09:11 AM
05/21/11 09:11 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
take the filter out and try it . I would run larger fuel line and atleast a real 3/8 or larger filter .The fuel gauge it's self could be a resriction . keep us posted DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: coronet deluxe]
#988179
05/22/11 09:07 AM
05/22/11 09:07 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Two reason I know of for seeing air in that filter.
Heat-Gas is boiling in the line causing air to accumulate in the filter.
Other is pressure surges from the needle and seat. This is kinda complex. Never really seen this first hand. But, was told by a veteran Comp racer that when the needle drops allowing fuel into the bowl every thing is great. Then is slams shut causing a reversion in pressure. If it opens again soon enough after closing and catches that reversion supposedly you can actually get air into the fuel line.
The last one I have never actually watched and personally seen happen. I understand some of what is being said because I have seen a similar situation in an intake manifold with parts coming apart in one cylinder ending up all through the intake manifold and into other cylinders.
If the air in the filter really bothered me and I had already tried standing the filter up first. You could try a fuel return system. I think Magnaflow makes an adapeter that goes between the hose and the fuel bowl. This adapter allows you to hook a very small line up that returns air and fuel back to the tank. It is a lot of trouble to do for a street car and would probably be something that you would have to homemake considering the plumbing you are using.
Leon
[Re: Leon441]
#988180
05/22/11 11:32 PM
05/22/11 11:32 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would think you will be better off with the filter down low, out of the engine compartment heat. Maybe a good phenolic spacer to help the carb too. But before you quit and feel it is all fixed, it would be a good idea to check the entire system, starting with a flow test of the pump, then move up the line all the way to the carb one piece at a time. that way, when the summer heat comes, you will be ready!
