It's been awhile since I have been able to get any work done on the Charger but the body work may be nearly completed and I wanted to go ahead and get the emblems put on the body.
The problem I face is it seems that almost every 73-74 Charger I find pictures of (including mine) seems to have the emblems in a slightly different spot. I want to know if anybody here knows the proper location of the "Charger"/"arrow" emblems that go on each door and the "Dodge"/"Charger" emblems that go on the decklid.
My Charger had the Dodge/Charger emblems on the right side of the decklid diagnal to each other. However I see a lot of other 73-74 Chargers that have the "Dodge" emblem left and "Charger" emblem right. Same goes for the door emblems where I see the "arrow" emblem front to the "Charger" emblem and vice versa. Which is factory correct??
Does anybody here have P/N's and/or pix of the the correct placement? Any help here with information or good vendors that make these emblems (or NOS) for the 73-74 Charger SE?
Thanks in advance, guys!
