pre made braided brake lines..where?
#986103
05/04/11 02:59 PM
05/04/11 02:59 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
in couple days will have angies rear housing back (converting to disc brakes) i will needing some braided brake liness where is best place to get them? did you buy them pre made?,make them your self? i assume the fittings are crimped?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: pre made braided brake lines..where?
[Re: topside]
#986107
05/04/11 05:05 PM
05/04/11 05:05 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have had great luck with TMR in the past. Torino Motor Racing 714-771-1348 Orange Ca ![](/ubbthreads/images/graemlins/thumbs.gif)
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: MR_P_BODY]
#986111
05/04/11 06:14 PM
05/04/11 06:14 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
so would you use a male end for the y block on the housing and a female end on the caliper end? what size is the fitting that would go into the caliper?(non banjo) i dont want black hyd hoses at all so would have to be able to thread a - size hose end onto/into it thanks
[Re: toplescuda]
#986116
05/05/11 12:28 AM
05/05/11 12:28 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
what size line -3 or -4? also sence i dont have the housing with me what size fittings go into the brake splitter block? thanks
[Re: toplescuda]
#986117
05/05/11 11:03 AM
05/05/11 11:03 AM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
What rear brakes are you using? If they use a slider type caliper I'd keep the flex line short. My wilwoods have fixed calipers so I used hard line for all of it. On the front flex lines I used -6AN, IIRC the Y block should be 3/16" inverted flare. Edit** I used -3AN, getting old sucks ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: justinp61]
#986119
05/05/11 11:33 AM
05/05/11 11:33 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
they are for a 85 s10 they slide type where the fitting go it donn have anything to bottom out on reason i was thinking a pipe thread
[Re: Challenger 1]
#986121
05/05/11 01:31 PM
05/05/11 01:31 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
the reason was gonna use braided line was incase had to remove caliper wouldnt bend the heck out of the hard line heck i can make hard line
[Re: toplescuda]
#986122
05/05/11 04:16 PM
05/05/11 04:16 PM
Challenger 1
Cincinnati, Ohio
Ummm, you have to use short section of flex brake line with disc brakes...you sure you should be working on brakes?
