Re: pre made braided brake lines..where? [Re: Challenger 1] #986123
05/05/11 04:26 PM
05/05/11 04:26 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
thats why i was gonna make both sections on the housing with braided stainless,last thing i want is a bunch of connections i dont have to have
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: pre made braided brake lines..where? [Re: toplescuda] #986124
05/06/11 10:26 PM
05/06/11 10:26 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
These guys have everything you could possibly need. godman highperformance
Re: pre made braided brake lines..where? [Re: toplescuda] #986125
05/07/11 12:46 AM
05/07/11 12:46 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
they are for a 85 s10 they slide type
where the fitting go it donn have anything to bottom out on reason i was thinking a pipe thread
You will need a short flex line with slider type calipers. My Wilwoods are fixed, that's how I could get by with all steel with no flex lines.
Re: pre made braided brake lines..where? [Re: Challenger 1] #986126
05/07/11 11:23 AM
05/07/11 11:23 AM
ky
68roadrunner Offline
ky
You will need to weld a bracket at the end of each housing tube to fasten the steel line, from there it goes to braided line, there should only be 12" or less on each side. If you use all braided line the petal will be too soft.
Calibors will have #3 or 4 straight thread or even metric, I'm pretty sure.
if you run flex from the caliper to the y block you will have a sponge pedal from the hose swelling a little. only use as much flex as has to for movement areas.
strange has some good info on their website.
