Well I talked to the crew at Firm Feel and they said that running good quality ps fluid is not a problem for their pumps. They did bench test it with a atf and mobile mix and they run that in all their cars for years. I don't remeber what the oil ir wt was as I had a few drinks after the job was done and the the box was already in.
![](/ubbthreads/images/graemlins/beer.gif)
I beleive with new box with new seal would go either way. Once the seals soak up whatever oil was used first, that's probably what should be used in it. Power steering, ATF of special mixes will will be for diffrent units, so best to use what your comfertable with.
