Re: BB - distributor drive gear bushings
[Re: ebodyseast]
#985521
05/03/11 06:28 PM
05/03/11 06:28 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I replaced an aluminium bushing in a 68 block with a bronze bushing. I assumed they were aluminium from the factory but maybe it had been replaced some time in the past.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: ebodyseast]
#985522
05/03/11 06:30 PM
05/03/11 06:30 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some later blocks had a bushing that resembles aluminum, dissolves quickly when the block is hot-tanked.
If you decide not to use the correct burnishing tool, check the fit of the intermediate shaft before assembling the motor.
[Re: buildanother]
#985524
05/03/11 07:10 PM
05/03/11 07:10 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
I have not seen a new alum(silver) one, but have seen some on blocks taken apart. (they were usually spinning in block- not good. I would also use the bronze unit, and they do sometimes (not always) fit shaft tight if you do not ream.
As stated above, to install it the correct way you do need the correct burnishing tool....IMHO ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: ebodyseast]
#985527
05/12/11 10:10 AM
05/12/11 10:10 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Ive torn a lot of blocks apart.All were bronze bushings.Never found an aluminum one in probally 50 blocks.Rocky
Chrysler Firepower
[Re: CR8CRSHR]
#985530
05/13/11 08:37 PM
05/13/11 08:37 PM
Posts: 7,664 IN
ahy
IN
Since I had a "near miss" on a bushing installed without the tool I will always use the bronze bushing and install with the busnishing tool. Last time I was able to borrow one from a Dodge dealer... next time I'll try to borrow agan and buy one if necessary.
