Dana 60 build #984889
05/02/11 02:31 PM
05/02/11 02:31 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I am working on building a Dana 60 to put behind my Hemi in my 68 Charger. I picked up a used truck housing that I am planning on converting to use in a car. I typically build jeeps so this is a little new for me to build a car axle. Right now I have a Jeep Grand Cherokee rear disc brake set up. The Jeep Grand Cherokee WMS is 61" WMS, its within an inch of the b body axle. I had a pair of Dana 44 front shafts that were laying around, they are the same spline as the 60, 30 spline, 1.310 diameter. I am planning on usiing a set of Jeep/mopar bearing ends, a typical jeep Dana 44 uses a Timken set 10 bearings, will they fit the Dana shafts? Are they similar to the Green bearings? Any help and advice would be appreciated. Tim
Re: Dana 60 build [Re: astjp2] #984890
05/03/11 03:44 PM
05/03/11 03:44 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
bump
Re: Dana 60 build [Re: astjp2] #984891
05/04/11 02:31 PM
05/04/11 02:31 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I guess its time for pictures...Here is a carrier bearing girdle I found with installation pics....
Re: Dana 60 build [Re: astjp2] #984892
05/04/11 02:32 PM
05/04/11 02:32 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
pic 2
Re: Dana 60 build [Re: astjp2] #984893
05/04/11 02:33 PM
05/04/11 02:33 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Pic 3
Re: Dana 60 build [Re: astjp2] #984894
05/04/11 02:35 PM
05/04/11 02:35 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
pic 4
Re: Dana 60 build [Re: astjp2] #984895
05/04/11 02:36 PM
05/04/11 02:36 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
pic 5
Re: Dana 60 build [Re: astjp2] #984896
05/04/11 02:37 PM
05/04/11 02:37 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
pic 6
Re: Dana 60 build [Re: astjp2] #984897
05/04/11 02:42 PM
05/04/11 02:42 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Dana 60 gears in a 60 housing
Re: Dana 60 build [Re: astjp2] #984898
05/04/11 02:43 PM
05/04/11 02:43 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Dana 70 gears in a 60 housing...note the clearance!
Re: Dana 60 build [Re: astjp2] #984899
05/04/11 02:46 PM
05/04/11 02:46 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Clearancing the top of the 60 housing.
Re: Dana 60 build [Re: astjp2] #984900
05/04/11 02:47 PM
05/04/11 02:47 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Clearancing the middle.
Re: Dana 60 build [Re: astjp2] #984901
05/04/11 02:48 PM
05/04/11 02:48 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Clearancing the bottom!
Re: Dana 60 build [Re: astjp2] #984902
05/04/11 02:51 PM
05/04/11 02:51 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Dana 60 and 70 comparison! This takes a heavy duty 35 spline Dana 60 rated for 6000lbs of shear force and gives it the 70 ring gear's 8000lbs of shear force.
Re: Dana 60 build [Re: astjp2] #984903
05/04/11 03:33 PM
05/04/11 03:33 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Sorry to hijack guys. But has anyone made my mistake. I started building a new rearend for the racecar and started with a Dana 70 by accident. I narrowed it and was about to weld everything up when I had a gut feeling that this housing looked too beefy. In researching it it is indeed a 70 housing. Now i have all the axles spool and guts from my previous 60 and was goind to reuse them. I realize the ring is bigger on the 70 and thus the larger housing but can the 60 parts be used in the 70 rather than me start all over again. I feel stupid but the housings are real close in appearance so I can't be the only guy to make this mistake. i have not measured anything to see if it will work as I just noticed it. Are the pinion bearings and side bearing sizes different. Obviously I can make the housing ends whatever I want but I think I am scrooood as I think I read somewhere the bearing sizes are different as well. Anyone know for sure----thanks
Greg
Re: Dana 60 build [Re: bcrproducts] #984904
05/04/11 05:07 PM
05/04/11 05:07 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Maybe, contact this guy, there are several links on Pirate4X4.com, search Jana 76. http://jantzengineering.com/index.htm
Re: Dana 60 build [Re: astjp2] #984905
05/04/11 06:56 PM
05/04/11 06:56 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Any more details on using a Dana 70 ring & pinion?
Re: Dana 60 build [Re: topbrent] #984906
05/04/11 07:32 PM
05/04/11 07:32 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I am still gathering my stuff, if you want to read the whole article, http://www.pirate4x4.com/forum/showthread.php?t=946421&highlight=jana+76 I found this working with my jeep stuff, the offroad guys have been doing it for about a year. The cost is probably about 300.00 more than a 60 if you are buying all new. Here is the link to the girdle cover. It is 250.00 for the cover and girdle assembly. http://www.pirate4x4.com/forum/showthread.php?t=958047&highlight=jana+76 Tim
Re: Dana 60 build [Re: astjp2] #984907
05/05/11 08:27 PM
05/05/11 08:27 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Re: Dana 60 build [Re: astjp2] #984908
05/07/11 12:22 AM
05/07/11 12:22 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I called about getting my housing narrowed and new ends put on. Including shafts and the ends it was 700.00. There is a 3 week lead time and the shipping quote I got was 115.00 each way. So now I need to get the 70 ring and pinion fit. I was also able to find an original dana 70 power lok for 150.00 used. Do these prices seem ok? Tim
