Re: How much does ignition timing affect 1/4 mile MPH.
[Re: Mick70RR]
#984851
05/05/11 10:28 PM
05/05/11 10:28 PM
Posts: 16,934 NC
440Jim
NC
IMO, most of the mph loss was the weather (temp, humidity, baro pressure, DA, and the wind). The ignition timing will effect the car/power/torque, but I don't think you will see that much from those two settings by itself.
Just to show how little it can effect things, and each car is different, this is my track testing. Now this engine doesn't need much timing; likely because it is flat top piston, 0.039" quench, good combustion chamber shape (Indy 440-1), 13.5 CR, on E-85 ethanol.
[Re: 440Jim]
#984852
05/05/11 11:15 PM
05/05/11 11:15 PM
Posts: 7,506 Az
Crizila
Az
Interesting stuff, and I agree. I run flat tops, good chamber and a tight quench on my 408 and I have done some timing testing with the same results - little change in ET / speed. I think this scenerio can be different when you have something impeding the flame front, start getting in to detonation, run way rich or lean, etc.
Fastest 300
