Re: Melling Big Block HV Pump Shaft Siezed - Anyone Els [Re: Sport440] #984396
05/03/11 08:32 AM
05/03/11 08:32 AM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
Oil pump was torqued properly. I must have installed at least 2 dozen over the last 35 years.
Pump never completely seized. It is very hard to turn by hand (with an intermediate shaft/gear, even with the outer rotor removed). Oil pressure drop may have been due to the main bearing failing and excessive clearance. So, it may have been binding up on it own due to poor manufacturing, due to residue from a bearing failure or who knows what else
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Melling Big Block HV Pump Shaft Siezed - Anyone Els [Re: Dads426] #984397
05/03/11 09:49 AM
05/03/11 09:49 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Try taking the center shaft out and put it in a drill press to see if it't bent.
