Re: Distributor Cap Blow off
[Re: 62maxwgn]
#983784
05/02/11 02:21 PM
05/02/11 02:21 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Boy John,never knew you were that easily offended. Why do you suppose they vent a cap ? !!!!!
A lot of it has to do with moisture, the vent gives it somewhere to go instead of creating corrosion.
[Re: Mopar_Country]
#983785
05/02/11 02:25 PM
05/02/11 02:25 PM
Challenger 1
Cincinnati, Ohio
Yea, it's not there to relieve pressure. The OP either has a cheaper dist cap, cheaper dist or it's not on right. imo Maybe he has wrong parts too.
[Re: RemCharger]
#983787
05/02/11 02:36 PM
05/02/11 02:36 PM
Challenger 1
Cincinnati, Ohio
I wd40'd my weights once, fired it up and,..POW! blew the sucker right off. Thats the closest I've seen.
![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Evil Spirit]
#983788
05/02/11 02:44 PM
05/02/11 02:44 PM
Mopar_Country
Under My Car
Vacuum advance diaphragm can fail, letting gasoline vapors get into distributor, ignite, and blow cap off. AMC's had this problem mid/late 70's.
Evil Spirit may have nailed it.
Because I am inquisitive in nature I had to ask. Spoke with an acquaintance of mine and he said the same thing, check your vac canister, after shut down gas vapors can come up the vac line and fill the cap with enough vapor to pop it of upon start.
That's not something I would have ever thought, and I have never seen it happen.
[Re: Mopar_Country]
#983789
05/02/11 03:03 PM
05/02/11 03:03 PM
Challenger 1
Cincinnati, Ohio
If that was the case, it would blow off as soon as he starts the car, which is not happening.
[Re: imfixinmopars426]
#983791
05/03/11 06:33 PM
05/03/11 06:33 PM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I have a brand new cap in the top of my tool box that won't stay put on the dist. It rocks back and forth popping the clips loose. I went and bought an accel cap and it didn't rock. Been running it wide open for a few years now without an issue. I don't really know why I haven't thrown that other one away yet. I guess its the horder in me...haaaaa.
I did have a small block ford dist grenade on me one time driving down the road. I was on the gas pretty good too. Put another cap and sleeve (busted that too) on it and took off again. Never did it again....
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: Evil Spirit]
#983793
05/04/11 08:41 PM
05/04/11 08:41 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Vacuum advance diaphram can fail, letting gasoline vapors get into distributor, ignite, and blow cap off. AMC's had this problem mid/late 70's.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: Caparco]
#983795
05/05/11 10:21 AM
05/05/11 10:21 AM
Posts: 5,270 Missouri
MY340
Missouri
Had a 79 Scout Terra with Chrysler electronic ignition and the cap kept coming off due to the clip issue on one side. I wired it down if I remember and no more problems with it coming loose.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: Challenger 1]
#983796
05/07/11 07:24 AM
05/07/11 07:24 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
That's exactly what would happen on my 75 Jeep CJ7. It would only happen when starting the car - never happened driving down the road. As soon as I cranked the starter, there would be a big bang from the distributor cap hitting the hood - maybe happened 1 out of 5 times I started the car. Popped the hood, clipped the distributor cap back on, and it would fire right up. I thought someone was messing with me the first few times it happened. Eventually I found out about the vacuum canister problem, replaced it, and it never happened again.
I used to have one of the clips come loose on the cap of the 318 in my 5th Ave. I re-bent the clip a few times until I got it so that it wouldn't come off any more, but it took a few tries to get it right. It seemed to be twisted a little and I'm guessing that's what caused it to pop off.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Evil Monkey]
#983797
05/07/11 09:43 AM
05/07/11 09:43 AM
RapidRobert
As said the clips need the same bend/tension on each side which is rarely a prob. I think the prob is the cap & I'd R&R it & maybe the clips from a junk dist & I'm assuming there is no rotor interference
[Re: RapidRobert]
#983798
05/07/11 10:59 AM
05/07/11 10:59 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The vacuum advance canister has no real direct path to the distributor internals in a stock Chrysler distributor. there are too many areas to vent any gas fumes out to atmosphere before it gets to the internals.
I doubt it's fumes.
It's possibly a worn distributor allow the shaft to move around knocking the cap loose or it's a bad cap.
[Re: badblubeee]
#983800
05/31/11 08:22 PM
05/31/11 08:22 PM
Posts: 59 Rhode Island
Caparco
Rhode Island
No this is not when I start.. starts fine.. its when you really give it the gas.. from a stop or passing on highway and I can't make it pop off in park reving the engine or with my head under the hood , in fear of damaging something! And blowing off isn't real correct.. the 2 clips stay on and it just cocks to one side.. throwing the timing way off.. popping and choking un- drivable someone said tie it down... but I really don't like this at all!!..LOL may work, ill have to see when i get her running but isn't this a electrical hazard!!.. lol got to be a better answer! ![](http://i711.photobucket.com/albums/ww120/Caparco/P5210712.jpg)
~ 72 Dodge Challenger ~ ~ 97 Dodge Neon ~ ~ 97 Dodge Ram ~
