Page 2 of 3 1 2 3
Re: Distributor Cap Blow off [Re: 62maxwgn] #983784
05/02/11 02:21 PM
05/02/11 02:21 PM
Under My Car
Mopar_Country Offline
Under My Car
Boy John,never knew you were that easily offended. Why do you suppose they vent a cap ? !!!!!
A lot of it has to do with moisture, the vent gives it somewhere to go instead of creating corrosion.
Re: Distributor Cap Blow off [Re: Mopar_Country] #983785
05/02/11 02:25 PM
05/02/11 02:25 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yea, it's not there to relieve pressure. The OP either has a cheaper dist cap, cheaper dist or it's not on right. imo Maybe he has wrong parts too.
Re: Distributor Cap Blow off [Re: Challenger 1] #983786
05/02/11 02:32 PM
05/02/11 02:32 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I wd40'd my weights once, fired it up and,..POW! blew the sucker right off. Thats the closest I've seen.
Re: Distributor Cap Blow off [Re: RemCharger] #983787
05/02/11 02:36 PM
05/02/11 02:36 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Distributor Cap Blow off [Re: Evil Spirit] #983788
05/02/11 02:44 PM
05/02/11 02:44 PM
Under My Car
Under My Car
Vacuum advance diaphragm can fail, letting gasoline vapors get into distributor, ignite, and blow cap off. AMC's had this problem mid/late 70's.
Evil Spirit may have nailed it.
Because I am inquisitive in nature I had to ask. Spoke with an acquaintance of mine and he said the same thing, check your vac canister, after shut down gas vapors can come up the vac line and fill the cap with enough vapor to pop it of upon start.
That's not something I would have ever thought, and I have never seen it happen.
Re: Distributor Cap Blow off [Re: Mopar_Country] #983789
05/02/11 03:03 PM
05/02/11 03:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
If that was the case, it would blow off as soon as he starts the car, which is not happening.
Re: Distributor Cap Blow off [Re: Challenger 1] #983790
05/02/11 04:13 PM
05/02/11 04:13 PM
michigan woods
imfixinmopars426 Offline
michigan woods
i would ck the end play of the dist,maybe the thrust washer is gone,and the rotor is pushing the cap up?
Re: Distributor Cap Blow off [Re: imfixinmopars426] #983791
05/03/11 06:33 PM
05/03/11 06:33 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I have a brand new cap in the top of my tool box that won't stay put on the dist. It rocks back and forth popping the clips loose. I went and bought an accel cap and it didn't rock. Been running it wide open for a few years now without an issue. I don't really know why I haven't thrown that other one away yet. I guess its the horder in me...haaaaa.
I did have a small block ford dist grenade on me one time driving down the road. I was on the gas pretty good too. Put another cap and sleeve (busted that too) on it and took off again. Never did it again....
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Distributor Cap Blow off [Re: StandOnIt] #983792
05/04/11 12:54 AM
05/04/11 12:54 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
vacumn advance canister is bad. suck on it with a rubber hose. it will not hold vacumn.
Re: Distributor Cap Blow off [Re: Evil Spirit] #983793
05/04/11 08:41 PM
05/04/11 08:41 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Vacuum advance diaphram can fail, letting gasoline vapors get into distributor, ignite, and blow cap off. AMC's had this problem mid/late 70's.
Re: Distributor Cap Blow off [Re: Mopar_Country] #983794
05/04/11 10:55 PM
05/04/11 10:55 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
That sounds like a good cause, not sure where my vac canister is or even if im running one!
But this is more ... when I gun the gas, on the road passing or from a red light... more feels like the other gent said the engine lift from a bad mount.. But there new
The vent info is great guys thanks, but its a capped vent and the cap never comes off..??.. or is this optional only.. you can run your car with no vent cap?
More info for the others who asked.. Small block 360, got the electionic conversion kit off some speedshop years ago.. red cap, no real markings on it.. "generic"
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Distributor Cap Blow off [Re: Caparco] #983795
05/05/11 10:21 AM
05/05/11 10:21 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Had a 79 Scout Terra with Chrysler electronic ignition and the cap kept coming off due to the clip issue on one side. I wired it down if I remember and no more problems with it coming loose.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Distributor Cap Blow off [Re: Challenger 1] #983796
05/07/11 07:24 AM
05/07/11 07:24 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
That's exactly what would happen on my 75 Jeep CJ7. It would only happen when starting the car - never happened driving down the road. As soon as I cranked the starter, there would be a big bang from the distributor cap hitting the hood - maybe happened 1 out of 5 times I started the car. Popped the hood, clipped the distributor cap back on, and it would fire right up. I thought someone was messing with me the first few times it happened. Eventually I found out about the vacuum canister problem, replaced it, and it never happened again.
I used to have one of the clips come loose on the cap of the 318 in my 5th Ave. I re-bent the clip a few times until I got it so that it wouldn't come off any more, but it took a few tries to get it right. It seemed to be twisted a little and I'm guessing that's what caused it to pop off.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Distributor Cap Blow off [Re: Evil Monkey] #983797
05/07/11 09:43 AM
05/07/11 09:43 AM
As said the clips need the same bend/tension on each side which is rarely a prob. I think the prob is the cap & I'd R&R it & maybe the clips from a junk dist & I'm assuming there is no rotor interference
Re: Distributor Cap Blow off [Re: RapidRobert] #983798
05/07/11 10:59 AM
05/07/11 10:59 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The vacuum advance canister has no real direct path to the distributor internals in a stock Chrysler distributor. there are too many areas to vent any gas fumes out to atmosphere before it gets to the internals.
I doubt it's fumes.
It's possibly a worn distributor allow the shaft to move around knocking the cap loose or it's a bad cap.
Don't be the exception.
Re: Distributor Cap Blow off [Re: Supercuda] #983799
05/07/11 02:03 PM
05/07/11 02:03 PM
Springfield Oregon
badblubeee Offline
super gas
badblubeee  Offline
super gas
Springfield Oregon
The only time I seen caps pop was on ol' Fords that had been fed a steady diet of Penzoil for too long
Also I have tried rotors for later model apps on an older car and they don't fit right cap wouldn't clip down right.
Re: Distributor Cap Blow off [Re: badblubeee] #983800
05/31/11 08:22 PM
05/31/11 08:22 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
No this is not when I start.. starts fine.. its when you really give it the gas.. from a stop or passing on highway
and I can't make it pop off in park reving the engine or with my head under the hood , in fear of damaging something!
And blowing off isn't real correct.. the 2 clips stay on and it just cocks to one side.. throwing the timing way off.. popping and choking un- drivable
someone said tie it down... but I really don't like this at all!!..LOL may work, ill have to see when i get her running but isn't this a electrical hazard!!.. lol got to be a better answer!
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Distributor Cap Blow off [Re: Caparco] #983801
05/31/11 09:27 PM
05/31/11 09:27 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
The top shaft has play and the rotor hits the cap/contacts..
Just my $0.02...
Re: Distributor Cap Blow off [Re: Caparco] #983802
05/31/11 09:59 PM
05/31/11 09:59 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
broken motor mount... engine pops up and hits wiper motor knocking it off.. dan
Re: Distributor Cap Blow off [Re: ph23vo] #983803
05/31/11 10:31 PM
05/31/11 10:31 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Thought of This!.. New mounts though
Lose rotor?.. how to fix?.. test?
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Page 2 of 3 1 2 3
