Re: AMC. Possiable 340 swap? [Re: V194] #983622
05/04/11 07:45 AM
05/04/11 07:45 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I'd love to do a 5.7 or 6.1 hemi into a '71 to '74 AMX.
Re: AMC. Possiable 340 swap? [Re: 71charger] #983623
05/04/11 12:48 PM
05/04/11 12:48 PM
SC
V194 Offline OP
V194  Offline OP
SC
I agree but we cant make it economically feasible to do it in a 60's or 70's MoPar let alone consider it for another body.
Re: AMC. Possiable 340 swap? [Re: V194] #983624
12/26/13 05:35 PM
12/26/13 05:35 PM
minnesota
dragdak Offline
dragdak  Offline
minnesota
This thread is kind of old but I have done 2 swaps already. Both were 6 cylinder 904 cars. First one was a 1981 spirit GT with a 440 and 727. The 2nd was a 79 spirit DL with a 318 and 904. Since the car was a 904 car and my v8 had a 904 I was able to use the orignal tranny mount, shifter, lines, driveshaft, speedo cable, and saftey switch. Needed the truck pan and pick up tube. Center dump exhaust manifolds.Mounts were just a flat plate welded to crossmember towars the front of it and a hole drilled thru it for the truck rubber mounts. Both were fast and fun.
Re: AMC. Possiable 340 swap? [Re: V194] #983625
12/27/13 02:50 PM
12/27/13 02:50 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
IIRC there used to be someone on here with a BBM in a Pacer. Still here? Is a Pacer engine compartment anything like a Hornet?
