Re: Thanks Again Mancini! [Re: Lee446] #983191
05/01/11 01:45 PM
05/01/11 01:45 PM
PA
moparacer Offline
moparacer  Offline
PA
I use the hi temp silicone on both sides of the fel-pro gaskets and they seal perfectly and become reusable as only the silicone sticks, not the gasket. I never tried silicone only, but like someone above said, if your flanges are true, it oughta work!
I always used gaskets when the flanges have the welded bead on the head surface. You just dont have as much surface area for the silicone to seal up when its like that.
If the flange is flat with no welded bead on it I just used silicone like the others say.
Also, I would think the wrong gaskets in the box would be a TTI issue and not Mancini.....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Thanks Again Mancini! [Re: moparacer] #983192
05/01/11 01:51 PM
05/01/11 01:51 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
high temp RTV here for years.in fact the only gaskets in my motor are head gaskers (copper)
Re: Thanks Again Mancini! [Re: moparacer] #983193
05/01/11 01:55 PM
05/01/11 01:55 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Nope. Russell at Mancini said his shipping dept. messed up.....
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Thanks Again Mancini! [Re: ChrgrCuda] #983194
05/01/11 02:03 PM
05/01/11 02:03 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
Well, they did it to me again. I had to order another set of TTI headeres gaskets for my 440. I said, "These are BB gaskets right?" They said, "Yep. Right on the shelf." I said, "So your sure these will fit my Indy EZ heads?" Mancini says,"Yes.". I say o.k., can I get these by Friday? Yes they should be there Friday. I just opened them up, and what did I get? Small block header gaskets. YAYYYYY! Awesome!!!! I get to wait another week for @#$%% header gaskets!! This is freakin' so awesome! Nobody in town carries header gaskets for a Mopar. They don't even list gaskets for as the local auto parts store asks, "Is that Charger a '68 or '69 Chevy?" Awesome! I give the hell up.
call your local Oreilly store they can get them in a day or sooner
Re: Thanks Again Mancini! [Re: ChrgrCuda] #983195
05/01/11 02:05 PM
05/01/11 02:05 PM
Super Scamp Offline
Super Scamp  Offline
Just put the Black RTV on the head side and carefully install your Headers ... use 12 point header bolts and call it a Day..... As for the gaskets leave them for the street cars.. They will change them twice a year and keep the gasket companys going..
I have never used gaskets on my headers ever..
Just One Man's Opinion Mopar Mafia Racing
Re: Thanks Again Mancini! [Re: Super Scamp] #983196
05/01/11 02:15 PM
05/01/11 02:15 PM
Super Scamp Offline
Super Scamp  Offline
Oh.. When you call Mancini again for parts ask for Art he will take care of your part problems, He knows Mopars..
Re: Thanks Again Mancini! [Re: Super Scamp] #983197
05/01/11 02:16 PM
05/01/11 02:16 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
I use the Mr.Gasket Ultraseal header gaskets with zero issues, I even re-use them 2 or 3 times.
I tried RTV only once and didn't like it but alot of guys do it that way. I thought it was hard to get the headers on w/o damaging the RTV surface and it was no fun to clean up the next time I removed the headers.
Re: Thanks Again Mancini! [Re: ProSport] #983198
05/01/11 02:24 PM
05/01/11 02:24 PM
Texas, USA
Texas, USA
That's why I'm so hesitant to use it.
Re: Thanks Again Mancini! [Re: ProSport] #983199
05/01/11 02:24 PM
05/01/11 02:24 PM
okla.
sam64 Offline
sam64  Offline
okla.
next time just tell the person at the local parts store that you need fel-pro 1414.
Re: Thanks Again Mancini! [Re: sam64] #983200
05/01/11 02:26 PM
05/01/11 02:26 PM
Texas, USA
Texas, USA
Thank you! That's good data. I will write that number down....
Re: Thanks Again Mancini! [Re: Super Scamp] #983201
05/01/11 02:39 PM
05/01/11 02:39 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I got my header gaskets from Mancini for my INDY heads and some more stuff i order the part numbers and i got the right ones from Mancini but if you get the wrong part it makes you mad as hell i can not get the silicone on headers to stay sealed up when i go on the 2 step after 4 or 5 times it blows out so i run only Mr gasket Ultra seal i get them from JEGS or MANCINI. GOOD LUCK.
Re: Thanks Again Mancini! [Re: ChrgrCuda] #983202
05/01/11 02:43 PM
05/01/11 02:43 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Same here I use the permatex ultra copper with no failure in 10 years...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
