Re: 727 Overheats!
[Re: fox]
#982456
04/29/11 09:31 PM
04/29/11 09:31 PM
Posts: 9,117 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Make sure the lower cooler line is the feed. If you run it thru the cooler top down it may not cool correctly.
Really? Doesn't the pump push fluid through the cooler at same rate regardless of line orientation?
Re: 727 Overheats!
[Re: 451Mopar]
#982463
05/02/11 11:02 PM
05/02/11 11:02 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
I had a torque converter with a crack in the hub where it goes into the pump and it leaked pretty bad, but that was a 904 transmission? I like the vent relocation to the rear of the transmission too.
x2
Re: 727 Overheats!
[Re: MarkZ]
#982464
05/03/11 01:16 AM
05/03/11 01:16 AM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
well its cooked! i think its the pump or the planetary gears making a ton of noise
Call me if you need help pulling it John. I've got the 5A all tore apart right now in the middle of a 518 swap.
ive been trying to get ahold of you, i dont think i have your number
