Re: Comp lifters stuck
[Re: boydsdodge]
#982323
04/28/11 11:49 PM
04/28/11 11:49 PM
They have been shipping lifters FILLED with I guess is WD40 stuff--we have been taking them apart draining-then putting it all back--this way the plunger moves so you can set the preload correct--hope this helps I have had comp hyd roller lifters that would stick in the down position --killed a couple of builds and customers confidence--they suck--Cranes were MUCH better and now there is another player that has decent units --being sold by folks under different names--don't know where they come from --good luck
