Re: World Record N/A Pass in an Lx/LC 10.38@129.88 !
[Re: fishy340]
#981193
05/01/11 12:54 PM
05/01/11 12:54 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
just wondering ...if that blue bee would improve with a little tighter converter? chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: RonP]
#981196
05/01/11 09:36 PM
05/01/11 09:36 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
ive known of only one to split the block at that power level. they seem to be holding up fine.
there are only two options on blocks. first is a stock iron production casting. the second is the mopar perf. aluminum block.
there are 6.1 iron block strokers out there making a tad over 1000 at the wheels these days. its not the normal occurance but still happening.
the classes they run in these days will allow them to drop down to a 4000 race weight btw, the transmissions are made by mercedes and the same units that went into the sl65 cars. so witha few upgraded sl65 hard parts inside them they will handle 1200 ft lb with ease.
the rears are becoming an issue now. some are bolting in 9 inch and 8.8 ford center sections. aj recently dumped a getrag 225 mm unit on the launch pad dropping the clutch at 4200 i heard. im not sure whos car that was though. it should be in the video i posted on the other post. maybe not.
steve-o steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: hemituner]
#981198
05/01/11 09:41 PM
05/01/11 09:41 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
wonder if it's still drive by wire????
The car is Still Drive By Wire. It also has cruise, all power options and AC. After the 10.38 I drove it home 440 miles in the rain I really Love it!! A.J.
Welcome AJ!
[Re: hemituner]
#981199
05/01/11 09:41 PM
05/01/11 09:41 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
AJ, never met you, but that is awesome. Wish you would have been at the Arringtons open house. We were all taking a good look at your car. Congrats again.
Thanks for the info Steve.
[Re: hemituner]
#981206
05/02/11 09:58 AM
05/02/11 09:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
wow I couldn't tune the lag out of my magnum. It would never launch the same way ever. Cool car.
