Pushrod Problems #979780
04/24/11 08:18 PM
04/24/11 08:18 PM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Went to run the 52nd Easter Bash @ Roxboro today, first pass car comes out of the water clean. Pull into the lights at the hit the car feels like it has no power go to second, no better kill it and let it coast off. Get it back to the pits I have a bent push rod on the #3 cylinder .What could have caused this ??? Everything else seems fine. Any idea or suggestions as to how to keep this from happeing again?? Thanks as always.
Chris
Re: Pushrod Problems [Re: hemiparts] #979781
04/24/11 08:27 PM
04/24/11 08:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
First thing I would have checked is the adjuster nut, did it loosen allowing the screw to back out? Second pull the lifter, check the bottom for wear, Hydraulic lifter, check to see if is collapsed.
Re: Pushrod Problems [Re: rowin4] #979782
04/24/11 08:32 PM
04/24/11 08:32 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
More info.... spring pressures, push rod specs, rocker ratio, PV clearance & anything else ya wanta share
Re: Pushrod Problems [Re: emarine01] #979783
04/24/11 11:54 PM
04/24/11 11:54 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Smith Bros push rods will STOP your problem i like to turn it up in the BURN BOX about 7,800 RPMs and i had a lot of problems but i got a set and i have had NO problems good luck.
Re: Pushrod Problems [Re: steeldust] #979784
04/25/11 12:02 AM
04/25/11 12:02 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They usually bend from some sort of interference, assembly issue or adjuster problem. One other issue is just a bad pushrod or not strong enough for the application but that is not something I have seen alot for sure. Either an adjuster backed out etc. An adjustment or assembly problem, meaning the cup was not in the adjuster properly or something hit something, meaning the valve and piston. Generally speaking the pushrod is the weak link here. Take a long close look at the spring, rocker, lifter and valve particulaly the adjuster, may be tell tale signs of the issue. A leak down will probably tell you if you had a valve piston issue...Good luck..
Re: Pushrod Problems [Re: hemiparts] #979785
04/25/11 11:03 AM
04/25/11 11:03 AM
Chris
How many runs or how long or miles where on the parts when the pushrod failed?
Re: Pushrod Problems [Re: Cab_Burge] #979786
04/25/11 11:54 AM
04/25/11 11:54 AM
Raleigh N.C
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Chris
New motor less than 6 passes.
Re: Pushrod Problems **UPDATE** [Re: hemiparts] #979787
04/26/11 08:39 AM
04/26/11 08:39 AM
Raleigh N.C
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
pumped air into cylinder and can hear air coming up through the intake. So we know at the least we have a bent valve. We'll start pulling the top end off today and look for other damage. Should of had enough clearance to keep valve out of the piston but we'll see..
Re: Pushrod Problems **UPDATE** [Re: hemiparts] #979788
04/26/11 05:43 PM
04/26/11 05:43 PM
NC
chris3 Offline
chris3  Offline
NC
New update. Pulled the head. #3 piston was at 45 degrees in the cylinder. A couple of nicks in the top of the piston. Pushed the piston and it went down in the cylinder. Valve bent. Problem appears to be new K1 Technology rod or rod cap. See "need Help"
Re: Pushrod Problems **UPDATE** [Re: chris3] #979789
04/26/11 05:52 PM
04/26/11 05:52 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I predict the rod didn't fail. It's usually the rod bolt.
* Were they ARP S2000 bolts?
* Installed using a stretch gauge?
Re: Pushrod Problems **UPDATE PART2** [Re: Mopar_Rich] #979790
04/28/11 10:32 PM
04/28/11 10:32 PM
Raleigh N.C
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Chris3 pulled the engine today and found that one of the ARP 2000 bolts backed off and allowed the bearing to escape and jam into the rod next to it causing 1 con rod to break and the other to be severaly heated and most likely unuseable
small chunk out of the block but nothing bad biggest concern will be the crank. We'll see tommorrow.
Re: Pushrod Problems **UPDATE PART2** [Re: hemiparts] #979791
04/28/11 10:43 PM
04/28/11 10:43 PM
rowin4 Offline
rowin4  Offline
Sorry to hear it was more than a bent push rod. Somebody didn't do some thing right to loose a rod in six passes.
Re: Pushrod Problems **UPDATE PART2** [Re: rowin4] #979792
04/28/11 10:47 PM
04/28/11 10:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sorry to hear about the issues. But pushrods dont usually just fail...
Re: Pushrod Problems **UPDATE PART2** [Re: Al_Alguire] #979793
04/29/11 12:08 AM
04/29/11 12:08 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Sorry man it was a little more than to many rpms.Good luck.
Re: Pushrod Problems **UPDATE PART2** [Re: steeldust] #979794
05/18/11 10:10 AM
05/18/11 10:10 AM
NC
chris3 Offline
chris3  Offline
NC
This is the latest in the broken 340. The ARP bolts in the K1 Technologies connecting rods were in fact tightened properly. All of the bolts in all of the remaining rods were still tight when I removed them.
The bolt were tightened in accordance with the torgue/angle instructions included by K1 Technologies. When I contacted them that was the first thing they said that they were not tight. Two people tightened the bolts with a new Snap On torque/angle torque wrench. I contacted White Performance in Tenn., the place we purchased the rods and bearings. At their request I sent the broken rod to them for checking. K1 continued to insist that the bolts were not tightened. I measured the stretch of the bolts, taken out of the broken rod, rod that had not broken and was still tight and a new unused bolt and verified that the bolts in the broken rod had been tightened. I received a call from White Performance verifying that there shop had confirmed that the bolts in the broken rod had been tightened and still backed out. K1 still will not discuss anything concerning this problem other than the bolts were not tight. I have a motor that has 6 runs on it with a torn up crankshaft, two bent valves and push rods scared block. White Performance has gone to great effort to assist in getting us back running with no consideration from K1 Technologies.
Re: Pushrod Problems **UPDATE PART2** [Re: chris3] #979795
05/18/11 10:20 AM
05/18/11 10:20 AM
Guitar Jones Offline
Wow, torque to yield rod bolts?
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: Pushrod Problems **UPDATE PART2** [Re: chris3] #979796
05/18/11 10:30 AM
05/18/11 10:30 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The best you will get from K1 is a new pair of rods, if you are hoping they are going to pony up to fix the rest the engine I wouldn't hold your breath. everyones favorite rotating assembly supplier would and has done the exact same thing, replaced the part that failed and it's your dime for the rest.
With any top end rod bolt that is the preferred method to torque the bolt , but you use a rod bolt stretch gauge not torque to yield.
Re: Pushrod Problems **UPDATE PART2** [Re: JohnRR] #979797
05/18/11 10:44 AM
05/18/11 10:44 AM
Yeah I get the stretch part, not the angle gauge part, I've never seen that on a rod bolt, seems like a stupid idea as I never thought that was a very accurate way of tightening a bolt.
Re: Pushrod Problems **UPDATE PART2** [Re: Guitar Jones] #979798
05/18/11 10:49 AM
05/18/11 10:49 AM
organ
maximum entropy Offline
organ
bolt stretch is by far the best method, and we have access to both ends of the rod bolts, allowing easy measurement. usually the recommended torque is exceeded by a significant amount to properly stretch the bolts. this situation sounds like either a bolt failure (not likely), or a bolt not properly stretched (probable). i also measure main stud and head stud stretch, fwiw.
Re: Pushrod Problems **UPDATE PART2** [Re: Guitar Jones] #979799
05/18/11 12:09 PM
05/18/11 12:09 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
K1 rods use torque and ANGLE. You use a preset torque spec, then use a angle guage to properly set the stretch. Its a very good system. Rod bolt stretch is still the preferred method, but I have never had an issue with torque and angle method, which I still use for all K1 rods.
I highly doubt this was a rod bolt failure in itself.(meaining a 2000 bolt just simply snapped off) I also highly doubt you'll get anyone involved in the assembly to say they made a mistake.If people are talking stretch, then the machine shop should be able to show you a list of what the before and after measurements were on the fasteners, if they cant, then they didnt use a stretch method.
The only way to truely rule out a catastrophic rod bolt failure ( which I still doubt) would be to send both rod bolts out of that ONE rod to an independant metallurgist for inspection.
Sorry to hear, but all you can do is move forward.
RIP Monte Smith
