Re: Pushrod Problems **UPDATE PART2**
[Re: CompWedgeEngines]
#979800
05/18/11 03:21 PM
05/18/11 03:21 PM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
K1 rods use torque and ANGLE. You use a preset torque spec, then use a angle guage to properly set the stretch. Its a very good system. Rod bolt stretch is still the preferred method, but I have never had an issue with torque and angle method, which I still use for all K1 rods.
Didn't know that, the last 2 engines I dealt with I had assembled by the engine machine shop due to time constraints. Todd do you also have to cycle the bolts X number of times before the final torque/angle set ?
[Re: astjp2]
#979802
05/18/11 03:31 PM
05/18/11 03:31 PM
JohnRR
A gulag near you.
The U.S. Army uses the same torque angle method on some of its really expensive and crititcal bolts on the Apache and Blackhawks. Tim
Do they use K1 rods?
[Re: maximum entropy]
#979804
05/18/11 03:51 PM
05/18/11 03:51 PM
moparpollack
Lil Herman
Lil Herman
85086
Blackhawk DOWN!!!!
[Re: astjp2]
#979805
05/18/11 03:52 PM
05/18/11 03:52 PM
Posts: 21,208 in a cattle trailer down by th...
Guitar Jones
I do a lot of torque to yield bolts, mostly in blind holes like head bolts and main bolts, I've just never seen that on a rod bolt.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: chris3]
#979807
05/18/11 10:08 PM
05/18/11 10:08 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
There have only been two people at K1 ever since I have known them, and Tom certainly should know what his tech sheet says,,,I dont understand that response at all. Oh well...just so that you dont think your losing it or going crazy...here ya go:
RIP Monte Smith
#979808
05/18/11 11:31 PM
05/18/11 11:31 PM
Guitar Jones
My Eagle H beams use the same listed ARP 8740 bolt. The stretch spec is the same but mine say 63 ft/lbs with out an angle. I still don't think angle is an accurate way to torque a rod bolt when you can measure the stretch.
