ballast resistor getting hot with key on? #979765
04/24/11 09:13 PM
04/24/11 09:13 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
just got dads satellite running,but the ballast is getting hot when the key on.what causes this? i put a new one on and a new voltage regulator,it was also charging wide open and the alternator is getting hot.please help!
Re: ballast resistor getting hot with key on? [Re: 1bad318] #979766
04/24/11 09:24 PM
04/24/11 09:24 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Hot ballast resistor is normal.
Re: ballast resistor getting hot with key on? [Re: 1bad318] #979767
04/24/11 10:03 PM
04/24/11 10:03 PM
Is the alt overheating now
Re: ballast resistor getting hot with key on? [Re: FuryUs] #979768
04/24/11 10:08 PM
04/24/11 10:08 PM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
so hot it burns your finger is not.dont know if its overcharging now,im done for the nite.check it tommorrow
Re: ballast resistor getting hot with key on? [Re: 1bad318] #979769
04/24/11 10:26 PM
04/24/11 10:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ballast hot enough to burn your finger is normal. It is a resisetor and creates heat just like a toaster. That is why it's mounted in a ceramic holder.
Re: ballast resistor getting hot with key on? [Re: stumpy] #979770
04/25/11 11:29 PM
04/25/11 11:29 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
And bolted to the firewall to dissipate heat. It is normal. A five Watt light bulb will burn your fingers and five watts on your ballast resistor is low.
Craig
Re: ballast resistor getting hot with key on? [Re: denfireguy] #979771
04/26/11 04:16 AM
04/26/11 04:16 AM
jacksboro,tn
1bad318 Offline OP
1bad440
1bad318  Offline OP
1bad440
jacksboro,tn
thanks guys.hadn't noticed that before.its charging good now.alt hand was between middle and charge with a weak battery,so should be ok once fully charged.
Re: ballast resistor getting hot with key on? [Re: 1bad318] #979772
04/26/11 07:43 AM
04/26/11 07:43 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Make sure the field connections on your alternator are nice and tight.
Re: ballast resistor getting hot with key on? [Re: ireland383] #979773
04/26/11 09:16 AM
04/26/11 09:16 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And if you just happen to be using a 60+ amp alternator with an old-style mechanical regulator, be prepared for hte regulator not to last forever. That's my experience anyway...
Re: ballast resistor getting hot with key on? [Re: Fury Fan] #979774
04/26/11 12:05 PM
04/26/11 12:05 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well I have been running aftermarket regulator since 7 or 8 years now, with a variety of alts ( 78 amps running now, but 60 amps by some years ) without any problems
