Re: Bench buffer/ buffing stainless steel trim?
[Re: coffeeman383]
#978740
04/23/11 12:28 PM
04/23/11 12:28 PM
Posts: 27,478 So Cal
autoxcuda
So Cal
Anybody got a bench buffer? Here's an 8" Craftsman one I'm looking at ($160!). Or do you just mount buffing wheels on your bench grinder? Anybody build their own (shaft, pillow blocks, etc)?
How do you buff your stainless trim?
Looks exactly like the habor freight one I got for $80. HF has two sizes. I got the larger one. You need to be very carefull with it. It's got lots of power and if you catch a part in it, it will twist it up or hurt you.
Be carefull with long thin curved parts: wheel moldings, some window trim, E-body/71-74 B-body lower window molding, etc Those piece with a higher powered buffer can catch and bent up a piece or put you in the hospital for stitches.
[Re: 268RTs4ME]
#978743
04/23/11 02:24 PM
04/23/11 02:24 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Couple suggestions, Wear heavy leather gloves... Just in case.... Often taping the trim to a piece of wood will help support it while doing the majority of the buffing... Always buff off the edge of trim, never onto the edge of the trim or A) buy spare trim B)buy more heavy leather gloves C) make sure your current on your medical insurance....
[Re: 1_WILD_RT]
#978747
04/24/11 09:51 PM
04/24/11 09:51 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I used a couple of small wheels mounted in my dremel and cordless drill. Either held the piece on a small table or in my lap, worked well on small trim around the windows. Probaly would used a wheel mounted in the air die grinder if I had to do it again.
[Re: 469runner]
#978751
04/25/11 04:47 PM
04/25/11 04:47 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I’m an amateur buffer also. Lots of good tips already mentioned, but I’ll throw in my .02. I use a Craftsman drill press with a radial/rotating head. Makes it easy to put the wheel at a good angle. It’s also able to set at different speeds, handy when using different-diameter wheels. Also puts the wheel out in the air with no guards/structure around it to interfere with handling the part. I use it because that's what I had at the time, and now I wouldn't use anything else. Taping trim to wood is a good idea, hopefully I’ll remember it next time I buff! When buffing stainless, I’ve found that a bit of heat seems to melt and flow the metal. When buffing a piece of long trim, whilst pushing it from 1 hand to the other (with the wheel in between), you can get a feel in one hand for the right amount of heat and set the pace that way. Yep, wetsanding can cut down on buffing time, but sanding takes time also. Sanding is ‘safer’, though, and less likely to have a part-launching event. Regarding gloves and a face shield: Gloves are a paradox IMHO. They’ll protect your skin, but are more likely to get caught by rotating items. And it’s a buffing wheel, so worst-case is you’ll get an annoying 1st-degree burn. Either way, your fingers shouldn’t be that close. Wear a dust mask under the face shield, and maybe some swimmer’s goggles. If I don’t, within a few hours after buffing I feel ‘fuzzy’ – my eyes, nostrils, etc, feel like there are fine cotton particles in them (because that’s exactly what happens!).
