Re: Master shut off with alt [Re: Bigcube] #978469
04/23/11 05:42 PM
04/23/11 05:42 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
If you want to do it the easiest way.... run the alt
output line back to the battery side of the master
exactly simple, and it would be protected..
I cant see any other way of running it on a race car
You can take that one step further and run a solenoid for the alternator output wire so that is not "hot" all the time.
The way mine is wired also with no tech problems.
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Master shut off with alt [Re: chryco] #978470
04/23/11 10:10 PM
04/23/11 10:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What ever happened to the kiss approach just run the output wire with chafe gear and some common sense
Re: Master shut off with alt [Re: '72CudaRacer] #978471
04/23/11 10:50 PM
04/23/11 10:50 PM
NC
chris3 Offline
chris3  Offline
NC
Brian, I don't remember what diagragm I had originally used but with the alternator wire connected the car would not shut off when the kill switch was turned off. I got a four post switch, I think from Mancini. I will be racing tomorrow; however, when I get home I will post how to wire it. With the car running it will shut off everything on the car.
Re: Master shut off with alt [Re: chris3] #978472
04/24/11 08:21 AM
04/24/11 08:21 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
This may sound stupid, but wouldn't it be better to run your power supply wire for your ignition directly off the master cut-off switch. Directly killing all power to your ignition when the switch is turned off. Would seem easier to do than the alternator wire. I'm not an electrician either, so....I could be wrong.
Re: Master shut off with alt [Re: 70HemiGTX] #978473
04/24/11 10:22 AM
04/24/11 10:22 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The cut off switch won't kill the running car, the alternator will back feed power to the ignition though the "cold" side of the switch and the car will keep running.
Re: Master shut off with alt [Re: 70HemiGTX] #978474
04/24/11 10:34 AM
04/24/11 10:34 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I thought the same thing about opening the ground to the MSD
I really don't like the rules about having the cut-off on the positive side of the battery.It makes much more sense to me to kill the negative side of the power source but thats my opinion
Gus
64 Plymouth Savoy
Dana 60
