Re: Holley Street Dominator Vs. Edelbrock RPM
[Re: Viol8r]
#977403
04/26/11 12:58 AM
04/26/11 12:58 AM
Posts: 10,241 Someplace you aren't
SomeCarGuy
I had a SD on a 72 440. Worked well. Put a RPM on it and it was much better. Little bigger carb than the Holley EFI I was running, 750 vs. 700. Had much better low end with the RPM. Running a SD on a low deck currently. I like it but can't help but wonder if that is why I seem to be down from previous MPG's from other 383s I have had with the stock intake on them. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: therocks]
#977405
04/26/11 04:40 PM
04/26/11 04:40 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
The SD is probally one of the best intakes made for a BB.I believe its about 1 inch shorter.The one I had on my 440 fits under the hood on my kids 62 300.Rocky
100%
[Re: DPelletier]
#977407
04/26/11 08:45 PM
04/26/11 08:45 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
Street Dominator = 455hp, 449 ft lbs
Performer RPM = 451hp, 457 ft lbs
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/index.html
....to me it doesn't look like enough difference to worry about at the 450hp level.
In the article you linked to , if you only look at the peaks, they seem similar. But look at the numbers at 3000 rpm: 381 ft-lbs for the SD, 408 for the RPM. In a car with a low stall converter,I would expect the RPM to have noticably better low end than the SD. Oops, I guess I should read all the posts, not just the last few. I don't think you can directly compare the B versions of those intakes to the RB versions. I have heard more than once that the RB SD is better than the B. I suspect that the RB version is a better low end torque producer due to the slightly longer runners . Anyway.... after reading the OPs combo, I would bet that on the strip, the SD and the RPM would probably E.T. very close to each other. On the street, when you don't feel like downshifting, the RPM may be a little more responsive.
[Re: forphorty]
#977408
04/26/11 11:34 PM
04/26/11 11:34 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
First hand experience on my 71 Bee / Street car #s 383 Mag / Balanced / .030 Over Forged / Old school Mopar 284-484 cam / 18 initial - 38 total / 3:91 Gears / Blah Blah
The 383 Holley Street Dominator off idle or launching at say 2500 rpms is a dog - That intake does not come alive until at least 3500/4000 Rpms and anything above that it flat out performs
However
The Edelbrock Performer RPM / Even just the Edelbrock Performer is just a much better intake on a mildly built 383 Mag Street Car
Like others have stated - On the 383s the Street Dominator just doesnt have the low end torque and it really shows in that Hot Rod Article and from my experience testing all three intakes on the street launching / off idle etc.
Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: GomangoCuda]
#977412
04/27/11 11:34 AM
04/27/11 11:34 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
I tried both years ago, and found very little difference between the two on my old reringed '73 440. 12.60s with the SD, and 12.50s with the RPM, MPH was exactly the same between the two...the only time it would break 106MPH is when it had wheelspin. If it hooked up, it went 106 every time no matter what I did.
RPM felt perkier at small throttle openings when driving it easy. SD was also fine, but not quite as responsive to a light touch on the throttle. I had a 4 grand converter at the time, which should cover up any differences, but it was still noticeable.
I think I liked the rpm a little better on that combo but the difference was small, can't really go wrong with either one.
Rich H.
Esse Quam Videri
[Re: GomangoCuda]
#977413
04/27/11 12:33 PM
04/27/11 12:33 PM
Posts: 1,255 Slidell, LA
Ronnman
Slidell, LA
The graph info waspulled fron the following the Moparts Link: https://board.moparts.org/ubbthreads/show...e=1&fpart=1From: Dave Freiburger Date: 8/27/07 We have a winner: "I'll put the overall average TQ and Hp on the 6bbl, then the RPM, then the Torker." Here's what our test showed. Each test is an average of two dyno pulls to remove anomolies. The numbers shown represent average power from 2,500 to 6,000 rpm. However, even averages do not tell the entire story. For example, the Torker and the RPM have the same average numbers, but they are not the same: the power curves cross at 3,900 rpm, with the Torker making more high-end and the RPM making more low end. As for peak power, the Torker, Street Dominator, M1, and Victor were all at 455-456 hp at 5,900 rpm. Nearly every manifold made 450-460 lb-ft at 3,800-4,100 rpm. Most of the dual-planes were way stronger than most of the single planes at rpm points below peak torque. Duh. I think the tunnel ram would have done a lot better as a dual quad. I was surprised how well the Six Pack did, but I think that's because of this engine's low-rpm and low displacement. Six Packs have killed big power in other tests with other more radical engines. That just proves that you really have to consider the test before you can make a judgment call, and you can't just look at one point of data and say "that's best" overall. It will also be interesting to see how this may change when we put better heads on the engine. If the 906 heads are currently the restriction, then other weak points in the intakes will be revealed with better heads. More data in the December issue of HRM. 2500-6000 AVG 3000 4000 6000 INTAKE LB-FT HP LB-FT HP LB-FT HP LB-FT HP Six Pack 428 348 413 236 459 350 391 447 Torker 427 348 395 225 455 356 397 454 Perf RPM 425 346 408 233 457 348 392 448 Victor 383 425 346 M1 single 424 345 1x4 tr 425 346 TM6 424 345 DP4B 424 344 419 239 454 346 387 442 Performer 422 341 418 238 452 344 382 436 Action Plus 421 341 Street Dom 421 344 381 217 449 342 395 452 Team G 409 334 Offy 360 406 338 Offy 2x4 408 330 Offy DP 404 327 Here are just a few data points. Also, a reminder that this thing had STOCK heads. I think the heads were the restriction, therefore the manifolds did not make drastic changes; except for the really bad ones, the different intakes just wiggled the numbers around by 5-10 hp or shifted them to the low rpm (dual plane) or high rpm (single plane). I'm pretty certain there will be more difference between the intakes once some better heads are on the engine. I find that out at the end of the month. RPM LB-FT HP Street Dominator 3,000: 381, 217 4,000: 449, 342 6,000: 395, 452 RPM LB-FT HP Torker 3,000: 395, 225 4,000: 455, 356 6,000: 397, 454 Perf RPM 3,000: 408, 233 4,000: 457, 348 6,000: 392, 448 DP4B 3,000: 419, 239 4,000: 454, 346 6,000: 387, 442 Performer 3,000: 418, 238 4,000: 452, 344 6,000: 382, 436 Six Pack 3,000: 413, 236 4,000: 459, 350 6,000: 391, 447
[Re: Ronnman]
#977414
04/27/11 02:41 PM
04/27/11 02:41 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
That's a great article, but I hadn't seen the graph results before: thanks! ![](/ubbthreads/images/graemlins/thumbs.gif) It's sure nice to note that the 6 pack did so well, especially since it's the only stock manifold in the test. 450ish hp is a great comparison point as it's right where alot of enthusiasts are, power wise. I'd note that there was a follow up to this test at a higher hp level for those interested. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Ronnman]
#977415
04/27/11 03:35 PM
04/27/11 03:35 PM
Posts: 4,770 Moved to N.E. Tennessee
GomangoCuda
At the 4K point it shows the Torker as having less torque but more horsepower than the sixpack or the rpm. Looking at the formula for HP (Torque x RPM) / 5,252 = Horsepower you can see that at any fixed rpm if the torque is higher the HP must be higher also. Oh well not the first time a magazine goofed.
[Re: bee1971]
#977417
04/27/11 08:36 PM
04/27/11 08:36 PM
Posts: 3,095 Idaho
Runner
Idaho
However
Scott
what torque converter are you running? i ran the same combo for 10 years, that cam in the 383 has more to do with it being a dog below 2500 rpm than the intake does. the more gear and converter i pit in mine the faster it went, however i started out with a dp4b intake, then tried a torker, then a tm6 and the last intake i tried was the performer rpm.
