Re: 701 HP Small Block
[Re: RAMM]
#976919
04/21/11 10:32 PM
04/21/11 10:32 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
nice work,my motor with same heads that ryanj built for me,made 729hp 620tq w a 950 carb and pump gas,,,those heads make some some power
is that a flat tappet motor?
No it's a 269 roller @ 11:1 on pump 92.
I thought it was clear that a solid flat tappet was used. J.Rob
2 different motors - Ryan's is a roller - hughes is a flat
[Re: J_BODY]
#976922
04/22/11 12:25 AM
04/22/11 12:25 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
.....and one is pump gas, the other race fuel.
Our 400hp small block has gone 9.87. Never dynoed it, but I TOLD it that is was 400hp. 400 rarely breaks anything!
Based off our dyno, going by 9.80's 136/137 @ your weight, you're in the 670-680 range. That car does'nt ET well for the MPH.... Pretty typical good W5 motor. & I think it's broken it's fair share of parts already LOL.
The INDY heads certainly do make power, & they should for what you get wrapped up in a set cost wise. I tell prospective customers all the time, the ICH stuff is the highest $ 59 degree heads out there, but they are also the most powerfull... so...
[Re: RyanJ]
#976923
04/22/11 12:29 AM
04/22/11 12:29 AM
BradH
Jeez... I want me one of them 700+ HP roller cams for my 11:1 pump 93 440 big block!
[Re: Hoss340]
#976926
04/26/11 09:11 PM
04/26/11 09:11 PM
Quicktree
when the car is done i will post the time slips and video
good luck whats it going in?
