Firm Feel steering box questions...
#976507
04/19/11 07:00 PM
04/19/11 07:00 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I have read from several members about how happy many are with their rebuilt steering gear chucks. I had one rebuilt back in, oh.. 2003 or so. I opted for the Stage 3 rebuild. I used to own a Camaro that was set up for handling. It had HD springs, shocks, anti sway bars and an IROC 12.7 to 1 steering gear. I loved the steering feel and response of that car and wanted to duplicate it with my Charger. The Stage 3 was purported as being nearly as stiff. It was not. While it gave more effort than the usually overboosted Chrysler power steering, it was still not to the point that I wanted. I later added the Fast Ratio idler and pitman arms, and THEN it felt right. Lately it seems that the gearbox has loosened up to the point where it has a sloppy "dead spot" from 11 to 1. (Using a clock as a reference point)I can't imagine that the set screw has backed off, but who knows. The car has TTI headers so adjustments are not an easy thing to do. I am curious if other Firm Feel customers have had this problem. When I first installed the box way back when, it felt as tight as a new car. Now, lane changes or sudden maneuvers take more turning of the wheel and less "feel". NOT good. I'll take the time and try to adjust out the slop, but it seems that in some cases, once wear begins, its all downhill from there.
Re: Firm Feel steering box questions...
[Re: Skeptic]
#976510
04/19/11 08:53 PM
04/19/11 08:53 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I'm a mopar guy but come on...You won't get that IROC camaro feel out of the firm feel box and old sheetmetal... ![](/ubbthreads/images/graemlins/laugh2.gif) At least not without some major mods... Seriously though, as Steve has suggested if the parts were somewhat wore to begin with who knows....And checking the K and box out is right on track also.... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ... There was a post where you can put a restrictor inline at the pump which does get you closer to the feel you're after {assuming you address the slop issue}...I think the discussion came out of a Mopar Action article a year or so ago...I remember reading the article....EDIT: I do remember one box I recieved from them where that adjuster nut was loose...It did move on the road test and I felt the slop you're describing but it was leaking out the adjuster so that was a quick give-away on that problem... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Skeptic]
#976511
04/19/11 08:54 PM
04/19/11 08:54 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
First I'd suggest you check to see where the slop is, i.e. the coupler, box-the mounting bolts can loosen up, and even cause flexing on the K member. I didn't notice any problems with my stage 2 box , but have replaced 3 idler arms after installation. I've got 255/50-17s on the front of my barracuda, with a late K-member IIRC '75.
Agreed, check the steering gearbox to K-member bolts. If you are running sticky tires with the fast ratio pitman arms it will work the box loose if you don't have the K-member reinforced. I run sticky 245/45/17's on my challenger with the FF box and the T/A fast ratio steering and had to tighten it up periodically. Its not a problem though if you aren't running the sticky tires and pushing it hard though.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#976512
04/19/11 09:01 PM
04/19/11 09:01 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
-Jon
Someone here or on another list had loose steering gear bolts recently. He thought they were fine and he checked them. But he went back and spotted the loose ones.
[Re: screamindriver]
#976513
04/19/11 09:06 PM
04/19/11 09:06 PM
autoxcuda
So Cal
I'm a mopar guy but come on...You won't get that IROC camaro feel out of the firm feel box and old sheetmetal... ...
But he was just saying it's not like it was when it was newer/new with the fast ratio arm installed. Something seems to have changed.
How many miles are on the steering box?
[Re: jcc]
#976519
04/20/11 09:48 AM
04/20/11 09:48 AM
Posts: 411 Texas
vynn3
Texas
YES, I have large, sticky tires on the car: 275-40-18 Nitto 555.
Yes you do, and you likely are in a very select group here with that much front end tire on a old mopar.
Yeah, and I bet it looks GREAT! ![](/ubbthreads/images/graemlins/devil.gif)
[Re: Kern Dog]
#976521
04/20/11 03:09 PM
04/20/11 03:09 PM
Posts: 6,236 san diego
JonsGottaDusta
san diego
Wow. whats this? POSITIVE responses instead of calling my car a DONK? Is this REALLY Moparts ?
I want pics ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Kern Dog]
#976522
04/20/11 05:51 PM
04/20/11 05:51 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Ok, if you miss it. Your cars a over heating DONK (what ever that is?)!
